Re-use headgasket if torqued but never used?
Old Dec 23, 2001 | 05:12 PM
Teal95Coupe's Avatar
Default Re-use headgasket if torqued but never used?
If you torqued down a head gasket but never started the engine can you re-use it?
Old Dec 23, 2001 | 06:39 PM
willyb94's Avatar
New User
Default Re: Re-use headgasket if torqued but never used? (Kyoko-Chan)
I wouldn't. It's not worth the risk of blowing a head gasket or ruining you're engine. Just go buy a new one.
Old Dec 23, 2001 | 07:27 PM
rainforest's Avatar
Default Re: Re-use headgasket if torqued but never used? (willyb94)
no way man if it was torqued down allready
Old Dec 23, 2001 | 08:26 PM
Mista Bone's Avatar
D Tranny Guru
Yep, done all the time.
But as with ANY headgasket, you should retorque at 100 miles, 500 miles, and at first oil change, 1000-1500 miles.
Old Dec 23, 2001 | 10:28 PM
samiam's Avatar
Thats a "no-no"
Old Dec 23, 2001 | 10:52 PM
RedlinedVTEC's Avatar
Default Re: Re-use headgasket if torqued but never used? (samiam)
Yeah dude you can reuse it, you're going to be fine. Seen it done quite a few times on gaskets that weren't quite as new as yours but still new. And have never had any problems with them. You'll be 100% ok.
Old Dec 24, 2001 | 07:25 AM
earl's Avatar
Default Re: Re-use headgasket if torqued but never used? (RedlinedVTEC)
I've done it with success...but maybe I was lucky?
Old Dec 24, 2001 | 08:04 AM
speedymon's Avatar
Default Re: Re-use headgasket if torqued but never used? (earl)
so let me get this straight. If i buy a 100+ dollar headgasket to lower compression, if i open up the engine again i have to buy another?
Old Dec 24, 2001 | 08:57 AM
earl's Avatar
Default Re: Re-use headgasket if torqued but never used? (speedymon)
Buy a Cometic for less than $100, custom pick your thickness and they are reusable. I currently boost 22 lbs (soon to be 30) on a reused Cometic.
Old Dec 25, 2001 | 12:11 AM
Mista Bone's Avatar
D Tranny Guru
I4 guys are lost, takes a V8 dude to lead the way.
Ask grandpa how HE did a headgasket.......
torque, retorque, and retorque again.
Old Dec 25, 2001 | 08:30 AM
speedymon's Avatar
Default Re: Re-use headgasket if torqued but never used? (Mista Bone)
Good idea. Headgasket is a headgasket right?
Old Dec 25, 2001 | 10:13 PM
mannyman's Avatar
El Veterano de Sur Califas
cometic headgaskes are reusable???? i didnt know that.
Nocturnal
34
Oct 17, 2023 04:04 PM
nate1229
Nov 8, 2014 12:10 AM
buddy190
Feb 10, 2009 05:51 PM
boomersz
10
Apr 11, 2007 04:37 PM
Rob Dizzle
Jun 30, 2003 03:57 PM
