help guys
Old May 18, 2002 | 07:31 AM
p-boy's Avatar
Default help guys
here the problem.. im runin a b16a (eg) with itr intake manifold( injectors, fuel rail,fuel reg and t/b all from a jdm itr) im using a spoon ecu. headworks (valve job p&p milled(1mm) aluminum retainers and springs) running ctr slugs and jdm 4-1 for the exhaust.. how come im runnin rich? my plugs always foul up i have to keep on cleaning them with thinner.. im using bkr6e (ngk-ordinary) anyway wat seems to be the problem? any solutions? help!!!!
Old May 18, 2002 | 09:19 AM
Kamin's Avatar
Default Re: help guys (p-boy)
it could be the spoon ecu
Old May 18, 2002 | 09:33 AM
p-boy's Avatar
Default Re: help guys (KAMiN)
hmmm..wat you think should i do? by the way im runnnin spoon cams too.. should i add a regilator or somethhing?
Old May 18, 2002 | 07:56 PM
p-boy's Avatar
hey guys just boght a new hks fuel regulator to try solvng this prob .. hmmm.. wat psi should i set it to?? help!!!!!
Old May 19, 2002 | 02:13 AM
JeffS's Avatar
Nobody can guess at this... it needs to be professionaly tuned.
Old May 19, 2002 | 02:33 AM
p-boy's Avatar
Default Re: help guys (JeffS)
aight mang tanx anyways
Old May 19, 2002 | 03:13 AM
p-boy's Avatar
wat i want to know is what would e the stock fuel pressure on a b16a with a stock pump and itr injectors?! im gona add the regulator tom.. so il what psi i will start workin with.. il lower the psi cause im runnin pretty rich so i need the stock psi formy setup pls help katman rainforest anyone?!?!
1990EF8
Feb 19, 2006 05:38 PM
ITR607
10
Dec 8, 2002 10:21 PM
Stinkalope
Feb 22, 2002 09:01 PM
teg92
Jan 10, 2002 04:36 PM
6SPD_EK
Jul 10, 2001 10:24 AM
