Flat spot after JDM header install...
Old May 17, 2002 | 04:49 PM
CKDC2's Avatar
Default Flat spot after JDM header install...
Just installed my DC JDM header on my '95 GSR with R cams. Car runs good from 0-4400 rpm, at 4400 the car loses major power and it does not pick up again until about 5200 rpm. Had the gears adjusted at -3 exhaust +2 intake for old set-up. Put gears back at zero. Still have dead spot. Had fuel pressure at 54 lbs with hose off regulator, tried 56 lbs and 52 lbs- still has major flat spot right at vtec. A/F meter doesn't read lean or rich at that moment.
Anyone have any idea's besides "hit the dyno"
Thanks
Old May 17, 2002 | 10:24 PM
SMSP's Avatar
Default Re: Flat spot after JDM header install... (CKDC2)
Have you installed the adapter yet. If not wait until you do and then see what happens.
[Modified by SMSP, 11:26 PM 5/17/2002]
Old May 17, 2002 | 10:54 PM
CKDC2's Avatar
Default Re: Flat spot after JDM header install... (SMSP)
Adapter is in. Why would a free flowing exhaust create a dead spot at vtec engagement? All that was changed was header. Hmmm.
Old May 18, 2002 | 12:01 AM
Sonny's Avatar
Try advancing the exhaust cam a little bit. Maybe +2 intake and + 1 exhaust. My car liked that. My Skunk2 cams ran best at +5 intake, +2 exhaust.
Sonny
[Modified by Sonny, 9:03 AM 5/18/2002]
Old May 18, 2002 | 12:38 AM
ALLMOTOR18's Avatar
what is your vtec point?.. if you have a vtec controller, raise the vtec point from 4400...
Old May 30, 2003 | 08:39 PM
4drGSR's Avatar
I second raising the vtec point
b16a2typer
58
May 7, 2013 12:23 PM
T.J.
30
Jul 6, 2004 10:09 PM
civicsidavid
Apr 15, 2004 06:00 PM
Blue Liquid
Jan 24, 2002 10:56 PM
