Malpassi Fuel Pressure Reg
Old May 16, 2002 | 09:38 PM
Si_LuDer's Avatar
Default Malpassi Fuel Pressure Reg
Hay All.
I have a question for anybody running a fuel pressure reg on there H23 prelude.
I have a 92 Si with a malpassi FPR on it, now Im currently running 40psi however at time I have run 45psi which I do find a small increase of power. Id like to know what you guys normally run your Fuel pressure at. on my reg if I go to 35psi I found when revving when the tacho drops back down it almost stalls and then revs back up to about 600-1000rpm. the car is automatic but I doubt that it makes a difference if it was auto or manual when in park or neutral when revving?
anyways hopefully I get a reply? is 40/45psi to high or does it depend on the regulator?
Thanks all
Old May 17, 2002 | 12:43 AM
kinesistech's Avatar
Default Re: Malpassi Fuel Pressure Reg (GrooVe)
Set it at 45, dont forget to disconnect and plug the vaccum from the regulator when you set the pressure.
Opo
Jan 11, 2007 11:58 AM
danno33
Dec 27, 2006 02:16 PM
elpiar
May 30, 2006 12:25 PM
Shogun_HCI
Jul 31, 2005 02:33 PM
