HELP: Driving without brakes is not fun! =(
Old May 17, 2002 | 01:08 PM
Eskimo's Avatar
Default HELP: Driving without brakes is not fun! =(
Ok, so I was driving around in my 93 VX... I do my errands and get in the car to head home. Well, after about 5 miles, my brake pedal pressure is not firm anymore.
When I first tap it, it feels fine... but as my foot applies a steady pressure, the pedal sinks to the floor. I let go of the pedal and re-apply pressure and it's firm at first, but sinks to the floor.
I had to kinda drive with the parking brake for about 10 miles!
Here's what I know when I finally checked it out:
1. I checked the brake fluid level, it's all good. Caps on tight as well.
2. No dripping form the brake lines either, as far as I can see on the ground.
So, what could it be?
-Did the fluid get too hot? (It's only 90 degrees outside... probably ~ 150deg inside the engine bay.)
-Is my master cylinder going bad?
-What should I check for?
Thanks.
Old May 17, 2002 | 01:24 PM
Chiovnidca's Avatar
Default Re: HELP: Driving without brakes is not fun! =( (Eskimo)
Thanks.
If your not looseing fluid it's probably your master cylinder.
Old May 17, 2002 | 04:30 PM
EP3_05's Avatar
Default Re: HELP: Driving without brakes is not fun! =( (Chiovnidca)
I would have to agree with that. Sounds like the master cylinder is failing.
Old May 17, 2002 | 07:55 PM
Pelican's Avatar
Default Re: HELP: Driving without brakes is not fun! =( (91civic)
Happened to me. Same exact feeling. Real mushy unless you pumped it a couple of times, but still went to the floor. I replaced the Cylinder and it stopped on a dime after. We bled the brakes (in the right order) like 16 times trying to find out what it was. Didn't look like it was leaking, or bad. But A new one solved it. Not too Expensive either.
CivicTT
Dec 1, 2011 05:42 AM
jdmland
11
May 1, 2010 08:45 PM
CivicHP
Sep 30, 2005 01:32 PM
eg_92vxhb
Jan 8, 2003 02:58 PM
Eskimo
May 18, 2002 03:39 PM
