b series crank pulley
Old May 19, 2002 | 01:25 PM
out2wincrx's Avatar
Default b series crank pulley
does anyone know if a crank pulley of b18 will work on a b16 without damaging my engine if anyone knows let me know thanks
Old May 19, 2002 | 07:14 PM
Jared's Avatar
Default Re: b series crank pulley (out2wincrx)
It will work. They are all the same diameter except for the B20.
Old May 19, 2002 | 08:46 PM
tinkerbell's Avatar
Default Re: b series crank pulley (Jared)
does that mean the B20 pulley is an "overdrive" pulley?
Old May 19, 2002 | 09:21 PM
salbaje's Avatar
i had heard that b20 pulley can bring up your boost if you are using jrsc. up to 10-12 lbs. Anyone verify this??
Old May 20, 2002 | 03:59 AM
ultraspeed2nr's Avatar
Default Re: b series crank pulley (salbaje)
SOOO.. does that mean i cant use the N1 pulley for the B16 on my B20Vtec?? dayam... let me know.. not trying to blow my shizz up!! hahah
Old May 20, 2002 | 05:06 AM
EEK's Avatar
EEK
yes this is correct...I was sellin a jrsc kit with the pulley...works wonders
Old May 20, 2002 | 03:26 PM
Default Re: b series crank pulley (EEK)
Old May 20, 2002 | 04:10 PM
Kamin's Avatar
Default Re: b series crank pulley (ultraspeed2nr)
so uh
if your doing a crvtec
what pulley should you use?
a b16/b18?
Corksil
Jan 17, 2013 09:06 PM
VtecKiDD
Dec 9, 2009 07:36 PM
smokinsi
Sep 23, 2005 10:21 AM
infamousALLMTR
Oct 6, 2002 03:11 AM
