technical - O2 sensors disparity
Old May 16, 2002 | 10:22 PM
tinkerbell's Avatar
Default technical - O2 sensors disparity
i measured the output of my two O2 sensors with a calibrated A/F monitor and one was reading leaner than the other,
ie when swinging from rich to lean in closed loop at idle.
i replaced one sensor with a fairly fresh second hand one - so one is about 10'000kms old and the other is 80'000kms old.
just wondering if:
a. this is why my ilde swings 50rpm
b. it could affect performance in any way
TIA,
t..
Old May 17, 2002 | 02:04 AM
prelude-bb3's Avatar
Default Re: technical - O2 sensors disparity (tinkerbell)
Im in need of the technical values too the MAP sensor gives,wich value at top speed is good can i adjust there something (clean),or just buy a new one?
standard values should be for a 96 BB3 lude : 2.8V max and 0.98 @ cut off engine?
honda.lioness
Engine Management and Tuning
Feb 27, 2009 09:12 AM
jayman3.0
Feb 3, 2008 05:07 PM
youngvedder
Oct 24, 2004 12:42 PM
Maxime
Feb 24, 2004 11:05 AM
