hondata+12:1CR+91 octane???
Old May 21, 2002 | 07:57 AM
JaeOne3345's Avatar
Default hondata+12:1CR+91 octane???
ok i have searched, gotten close to what I have been looking for but nothing exact. this jalopy of a motor me and my friend are playing around with will be around 12:1 compression. most of the hondata post i see are usually regarding forced induction, and more tolerable CR's.
im curious if any of you out there are running lofty compression such as this on the street with pump gas?? currently whats in store will be p28 computer, maybe a type R or good aftermarket intank, adj fpr, and maybe 310cc injectors if i did need them.
this would all be on 91 octane. im thinking if hondata has the posibility to fuel moderately high boost applications on the street/pump gas, then my wishes shall be granted. with the funds, it looks like stage 2 and some dyno tuning is the answer. let me know what people who have used/have experience with hondata think. im not looking for he said she said.
thanks for the help.
Old May 21, 2002 | 08:06 AM
2point6's Avatar
Default Re: hondata+12:1CR+91 octane??? (JaeOne3345)
I have 2 engines (daily driven) on pump gas. One is a 12.3/1 lsvtec and the other is a 12/1 h22a. So far there hasen't been any major issues with detonation. I also use modified ECU's. The lsvtec has a locash ecu and the h22a has just a removed rev limit. Timing is stock, however as the temp here In Tucson goes up (summer months) I usually have to retard the timing a bit or run a mix of 100/91 octanes. I realize you were asking about the honddata set-up, but I thought this may be benificial as well.
[Modified by 2point6, 5:07 PM 5/21/2002]
Old May 21, 2002 | 08:12 AM
JaeOne3345's Avatar
Default Re: hondata+12:1CR+91 octane??? (2point6)
u running 91 in general most of the time tho or not? here in cali we have 91 water gas.lol
Old May 21, 2002 | 08:17 AM
CHEETAH's Avatar
Its more dependent on how efficiently built your block is, pistons cant have sharp edges, head chamber also, colder plugs, excessive fuel ... IOW playing iwth fire with that low gas, 93/94 is safe, 91 is really lucky.
Greg
Old May 21, 2002 | 08:22 AM
2point6's Avatar
Yeah, 91 is about all we can get here. There is a couple of places to get race gas of course, but 100 is available at the pump for $4.00+/gallon. This isn't realistic to use all the time, plus it is hard on o2 sensors. I usually mix the fuels for track use and for daily driving we just stick with 91. (sometimes my girlfriend puts in an octane booster of some sort) Her car is the lsvtec.
Old May 21, 2002 | 08:29 AM
2point6's Avatar
Default Re: hondata+12:1CR+91 octane??? (CHEETAH)
Greg
This is absolutely true. When I built the engines, I hand sanded all of the sharp edges on the pistons and the combustion chanbers. The locash ecu (mugen copy) does run rich so this helps "cool" the mix. We use stock NGK plugs, but running a colder temp make sense as well. Also, cams can affect compression as well, so this has been factored in as well. Longer duration (more overlap) cams can usually compensate for higher compression ratios.
Old May 21, 2002 | 02:26 PM
JaeOne3345's Avatar
good info guys..more more more
ttt
ErikDaGenErik
12
Apr 9, 2005 09:33 AM
boostedblack99
Jul 27, 2004 08:18 PM
TwistedHatch
19
Oct 20, 2003 02:21 AM
ping83
Aug 26, 2003 07:45 AM
DLB1994
Feb 23, 2003 05:27 PM
