Oil Temp vs. Oil Pressure
Old May 18, 2002 | 07:48 PM
teg92's Avatar
Default Oil Temp vs. Oil Pressure
I'm going to be getting an air/fuel gauge and I'd like to also get something to monitor some life signs from my baby. I was wondering which is a better sign to be monitoring, oil temperature or oil pressure? TIA
Old May 18, 2002 | 08:38 PM
Jared's Avatar
Default Re: Oil Temp vs. Oil Pressure (teg92)
definitely pressure.
Old May 19, 2002 | 02:00 AM
sgT's Avatar
sgT
Default Re: Oil Temp vs. Oil Pressure (ridge racer 2)
Both. Or just oil temp. Pressure will rise with temperature.
What? NO
oil pressure actually goes down when oil temp goes up, because oil changes
viscosity as it becomes hot.
If you dont track your car, then oil pressure alone is fine.
Old May 19, 2002 | 02:07 AM
JeffS's Avatar
Default Re: Oil Temp vs. Oil Pressure (sgT)
Agreed... oil temp is imporant to watch at track events (along with water temp) to let you know if your car is running too hot. This shouldn't be a problem on the street. Oil pressure problems can strike whenever and will let you know when to shut the car off to avoid potential damage.
Old May 19, 2002 | 05:05 AM
teg92's Avatar
Thanks guys. I am getting towards tracking the car and for now I just would like to keep an eye on things! Thanks!
an2ny888
May 6, 2013 10:31 AM
Jeff_B
33
Aug 7, 2008 04:54 PM
Flux
Mar 10, 2007 07:35 PM
btran
Jul 22, 2004 11:59 AM
15psi of fun
Jul 23, 2003 08:16 AM
