Launching Technique
Old May 21, 2002 | 02:36 AM
Eddoes's Avatar
Default Launching Technique
Anyone out there with a B20B/B16A? What rpm are you launching and shifting at? I am Having problems with traction, any suggestions?
Old May 21, 2002 | 08:38 AM
Eddoes's Avatar
Default Re: Launching Technique (Eddoes)
Any suggestions guys? Must be a couple of drag racers on this site.
Old May 21, 2002 | 10:02 AM
brcivic411's Avatar
i don't have that engine... and i don't drag race... but since nobody is answering your question, i will suggest that you try ES motor mounts or z10 radius arms.
Old May 22, 2002 | 01:36 AM
Turdblow rex's Avatar
After you stage hold her on the mat untill you see the last amber go on, (dont worry about rev limiter, the valves will float and keep it below 10,000) then sidestep the clutch, forget about the tach, just let her go untill she goes flat then shift. Oh yea, never let the accelerator off the floor from when you stage untill you get through the traps. (if you float valves when you shift you do it too slow!).
Drive it like you hate it, if you are afraid of breaking it, you shouldn't be racing it!
good luck
Leroy
Old May 27, 2002 | 01:39 AM
saso
Guest
Posts: n/a
Default Re: Launching Technique (Turdblow rex)
you are an *******
Old May 27, 2002 | 06:28 AM
Eddoes's Avatar
Default Re: Launching Technique (saso)
hello to u to
Old May 28, 2002 | 11:35 PM
JALOP B16's Avatar
try 3000 to 4000rpm
or in between that
Old May 29, 2002 | 02:00 AM
raene's Avatar
2800 with the tires at 28psi seems to work best for me.
Old May 29, 2002 | 05:47 PM
Quick 200k Mile Motor's Avatar
Default Re: Launching Technique (raene)
32psi @ 3000rpm
Old May 29, 2002 | 06:25 PM
riceboy's Avatar
Default Re: Launching Technique (Quick 200k Mile Motor)
A general rule of thumb in a FWD car is to launch about one thousand RPMs below your torque peak.
Old May 29, 2002 | 10:04 PM
dirtySOHC's's Avatar
good luck
Leroy
wat the hell are you talkin about........
Old May 29, 2002 | 10:16 PM
Halo's Avatar
Default Re: Launching Technique (dirtySOHC's)
I always use to launch at 3k but since I have a 6 puck non sprung disk I always sat there spinning my tires. I recently switched to 2500 and 30psi an dthat seems to be working the best. Moving from a sprung hub to solid disk takes some getting use to
Old May 30, 2002 | 05:03 PM
Dokta's Avatar
Default Re: Launching Technique (Halo)
28 psi? I hope you are not talking about tire pressures. I usually have my pressure at 13 - 18 psi when I'm at the track. You need it that low in order to get a big enought foot print, otherwise you will be going nowhere at the line, or getting there slowly. If you have crappy tires you shouldnt be at the track. Rev to around 4000-4400 (you need to find the right rpm for your car) when the stage lights up, then feather the clutch the instant before the green lights up. Slowly feed the throttle until vtec kicks in. When vtec hits, drop it to the floor. The shift from 1st to 2nd is critical. Try to make the shift as fast as possible with as little chirp as possible. This requires some fancy clutch work. 2nd to 3rd shouldnt be too tough, either speed shift or just brush the clutch.
Old May 30, 2002 | 05:11 PM
JV's Avatar
JV
Who?
Default Re: Launching Technique (Dokta)
I launch at about 3500rpm with 22psi in the front tires (Kumhos) and 44psi in the rears........HTH
[Modified by JV, 9:12 PM 5/30/2002]
Old May 30, 2002 | 07:13 PM
pelotudo's Avatar
<--Launches at about 3000@16psi, anything higher and VTEC hits too early and I get to eat dinner while spinning on the line..anything lower and I bog like a ****...
jB
Old May 31, 2002 | 12:50 AM
Dutchie's Avatar
Why not?
MR. BAR
38
Jun 3, 2005 03:31 PM
VTEC Visions
Mar 7, 2005 11:09 AM
stevescivic
22
Feb 28, 2005 11:02 AM
ITR-DC2
Feb 23, 2004 04:30 AM
V-SPEC 1
Jan 1, 2004 06:47 PM
