How to change a clutch?
Old May 19, 2002 | 04:06 PM
See Are X's Avatar
Default How to change a clutch?
someone want to run me through what exactly I need to do to change a clutch?
Old May 19, 2002 | 04:21 PM
raene's Avatar
Default Re: How to change a clutch? (See Are X)
#1 Jack up car on tall jackstands
#2 disconnect battery
#3 remove axles (that's a topic into itself)
#4 remove the shift linkage from the transmission
#5 disconnect electrical components from transmission, remove battery and battery tray
#6 place jack w/ 2X4 underneath engine
#7 jack up engine until you can see it raise in the bay
#8 remove the rear, front, and passenger-side engine mounts
#9 remove the transmission-to-engine and engine-to-transmission bolts
#10 pull transmission away from the engine, lower it to the ground, and slide it out under the car
#11 brace the flywheel and crack loose the clutch bolts
#12 remove the clutch
Then perform the steps in reverse... I don't think I forgot anything. HTH
Old May 19, 2002 | 05:21 PM
C-speed's Avatar
Merry xmas:
http://www.c-speedracing.com/howto/b...ch/clutch.html
lowtegsr
Sep 12, 2013 10:00 PM
Chee_dog
Apr 9, 2008 09:20 PM
steinbacheg6
Dec 28, 2007 05:07 AM
jsteezy1290
17
Apr 26, 2004 08:43 AM
SpeedMonkeyRacing
May 5, 2003 01:36 PM
