Compression Test???
Old Feb 27, 2003 | 09:50 AM
Convoy's Avatar
Default Compression Test???
just recently did a compression test and i need some help with the test's readings, the results we're
C1 170, C2 152, C3 161, C4 165
what can i conclude with these results?????
its a gsr block with JDM ITR pistons and rings(11:5), b16 head with spoon 2 layer head gasket
[Modified by MiggytiMaestro, 6:50 PM 2/27/2003]
Old Feb 28, 2003 | 08:50 AM
Convoy's Avatar
Default Re: Compression Test??? (MiggytiMaestro)
anybody??????
Old Feb 28, 2003 | 08:57 AM
TimoneX's Avatar
New User
Well if you did it correctly with the throttle open and a reliable gauge then I think you can concude that your compression is rather low and that #2 too low for comfort. I'd probably proceed by dropping a tablespoon of oil in each cylinder and repeating the test.
Old Feb 28, 2003 | 12:10 PM
XDEep's Avatar
Default Re: Compression Test??? (TimoneX)
ya thats even lower than stock b18 compression at 9.2, which should be around 180. i imagine you should be breaking 200psi easily. the good thing is 1 and 2 have only a difference of 11%. 15-20% means trouble.
so id go ahead and do like he said and retry with a dab of oil, make sure you do everything correctly, and if it comes out the same again go do a leakdown test to see where youre leaking the most.
Old Feb 28, 2003 | 02:16 PM
pennies_hatchie's Avatar
anybody??????
yeah, #2 is low...
it should be around the 160-180 range
Old Feb 28, 2003 | 02:31 PM
BangAccord's Avatar
Default Re: Compression Test??? (pennies_hatchie)
the reading for #2 is a little low, however, that's assuming he did the test correctley.....
Old Feb 28, 2003 | 04:54 PM
aeolus's Avatar
Default Re: Compression Test??? (BangAccord)
Im curious,did you do this while the engine was warm?How many times did you crank the engine?Id say with that set-up,you should be hitting like 250 psi after 5 cranks...easy.Anything lower than 200 could show that your rings are going bad or just didnt seat right.
SilkyJohnson
13
Feb 15, 2011 05:54 PM
Keeper1343
Dec 17, 2007 09:10 PM
94_civic_tuner
Oct 10, 2007 02:00 PM
Brad
Sep 8, 2006 02:13 PM
John.
Jun 12, 2006 08:45 AM
