welding different metals?
Old Feb 27, 2003 | 01:01 AM
94hondaLS's Avatar
Default welding different metals?
I was wondering if you could weld stainless steel onto cast iron? Im doing a custom turbo project and wasnt sure. I plan on welding a stainless pipe onto the exhaust side of the turbo which is cast iron. Also is it really hard to use a gassless MIG welder? this is going to be my first time useing a MIG. Ive used a ARC welder before though and its pretty easy. thanks to anyone.
Old Feb 27, 2003 | 11:26 AM
tpr's Avatar
tpr
Default Re: welding different metals? (94hondaLS)
In order to peoperly weld cast iron it needs to be brought (heated) up to a cherry red color then welded using a nickle rod. This is for cast to cast. Heating it up before welding eleviates the problem of residual stress due to the cooling of the weld, drawing the surrounding material to the weld causing high residual stresses which will crack with thermal cycling. I would call Natinal Welders supply and ask them if it is possible to weld to Stainless Steel in this manner. Also check with your local heavy truck repair shop. They typically try to repair the cast iron exhaust manifolds as they are really expensive to replace.
Old Feb 27, 2003 | 11:39 AM
One2chi's Avatar
whats a gasless mig welder.....i thought mig welding was different from arc welder becuase it used gas....anyone knwo of a good site that explains all about welding?
Old Feb 27, 2003 | 12:01 PM
CivicEK.PDX's Avatar
Default Re: welding different metals? (One2chi)
if you gonna use stainless then you need a tig welder. Mig is wire feed. Tig actually melts the metal. Tig burns at about 5000 degrees so its hot. I dont know anything about cast. Depending what you need to go....I would say sand your surface....then weld with using a tig machine.
Old Feb 27, 2003 | 12:26 PM
JimBlake's Avatar
Default Re: welding different metals? (CivicEK.PDX)
What's the outlet of the turbine housing look like? Why can't you find or make a stainless flange for the end of your pipe, then bolt it to the turbine housing?
Old Feb 27, 2003 | 01:06 PM
94hondaLS's Avatar
Default Re: welding different metals? (JimBlake)
thats a good idea i think ill do that
BeArDy
Welding / Fabrication
12
May 18, 2011 01:50 AM
90Rexx
May 18, 2010 09:56 PM
RTW DC2R
Apr 25, 2006 03:28 PM
skiwithcars
Aug 19, 2005 07:41 AM
a z n t a k
May 7, 2002 11:47 PM
