Service Connector
Old Feb 26, 2003 | 10:57 AM
Tegra's Avatar
Default Service Connector
Where is the service connector on a 95 LS?
Old Feb 26, 2003 | 11:03 AM
b19coupe's Avatar
Default Re: Service Connector (Tegra)
The SCS connector is above and behind the glove box on the right. Usually a grey or blue two pin connector.
Old Feb 26, 2003 | 11:04 AM
Kataku2K3's Avatar
Put your hand on the bottom edge of you glove box then go all the way over to the right side... You should be able to feel it... There should be 2 connectors in a green rubber anti-short pouch... If you climb under there you can easily see it above the ECU but closer to the door... If you still need help i'll take some pics on my friend's EG... Latez
Old Feb 26, 2003 | 11:16 AM
Tegra's Avatar
Default Re: Service Connector (Kataku2K3)
Ok thanks, I think I can find it. Pretty good description
JDM-EJ1
Northwest (Sales)
Aug 27, 2010 05:06 AM
qwik92hatch
Mar 27, 2006 07:05 PM
killer_Bseries
Mar 3, 2006 04:18 PM
92BlackSi
Mar 29, 2005 10:26 AM
HYBRIDHATCH92
Apr 14, 2002 01:33 PM
