How often should a PCV valve be changed on a 97 GSR????
Not sure. I have changed mine a couple of times, but it was never actually clogged up or non-functional. It's only $3 at the most. If yours has never been changed, a new one may give you a couple MPG's...
thats rediculous! maybe your talkin about the whole PCV system or somethin
[Modified by 10K2HVN, 5:49 PM 2/28/2003]
go to local auto store and get one.
I use carb cleaner and clean mine out...but they should be replaced every-so-often.
Nope, just the PCV valve.
Had it there on the counter, pcv valve $78 the guy said "yep, thats pretty expensive"
Needless to say, I just cleaned the old one.
All the thing is ia a one way valve, so it shouldn't go bad! Unless you got issues with your motor and you are sucking all kinds os **** through it
na.. I have seem them go bad on new hondas in the 1st year or 2. *shrug* just check em every now and then (like when U change your oil), they seem to just go bad some times.
