jun 3 cams
Old Feb 27, 2003 | 12:35 PM
Cashflo's Avatar
Default jun 3 cams
what are your thoughts on jun3 cams in a daily driver. they are going in a gsr with pr3 pistons. Let me know of the pros and cons. thanks in advance
Old Feb 27, 2003 | 12:44 PM
joe_bocc's Avatar
Default Re: jun 3 cams (eghead)
JUN III cams are said to be similar to Skunk2 stage 2 cams, I'm getting Skunk2 stage 2 cams. Its safe to say I think they are fairly well suited for the street.
Old Feb 27, 2003 | 01:16 PM
all motor b20b's Avatar
I had them in my car for a daily driver and they ran fine.
[Modified by all motor b20b, 3:16 PM 2/27/2003]
Old Feb 27, 2003 | 03:40 PM
Cow's Avatar
Cow
Default Re: jun 3 cams (all motor b20b)
Pros:
-JDM y0!!11
-Great power potential
-Nice power curve
-Better than Toda's
Cons:
-Might shred your timing belt (get a PE or Toda belt)
-Skunk2 mentions minor idle problems with their stage II's, so thats a definite possibility with JUN's cam.. shouldnt be bad though
-Need a lot of other complimentary parts to get the most out of them. I would recommend PCT (Civic R) pistons rather than PR3, or maybe even some aftermarket slugs with deeper valve reliefs
-Careful tuning required. Too much overlap and your valves will grab each other and your motor will make a cool crunchy noise.
HTH
Old Feb 27, 2003 | 04:41 PM
Al Bundy's Avatar
Default Re: jun 3 cams (Cow)
I have JUN 3's and daily drive with them at least 70 miles per day. No problems what so ever. No idle problems, no timing belt problems. I have stock timing belt. Installed these cams about 2 years ago. 70,000 miles and counting.
Old Feb 27, 2003 | 04:43 PM
Cow's Avatar
Cow
Default Re: jun 3 cams (Al Bundy)
Wow.. first time I've heard of people running stock Tbelt with big cams. Maybe you know something they don't
BTW, how often do you have to adjust your valves with those cams? More than stock?
Old Feb 27, 2003 | 05:17 PM
-Whitey-'s Avatar
alot of people use "big cams" and a stock timing belt or a new honda belt (same thing)
Old Feb 27, 2003 | 05:47 PM
Cow's Avatar
Cow
Default Re: jun 3 cams (-Whitey-)
So is all the stuff about needing a strong timing belt a load of crap? I can see the reasoning behind it; having cams which the small lobes are bigger than stock VTEC lobes can't be easy on the timing belt and valvetrain. More work = more stress.. yadda yadda
Old Feb 27, 2003 | 05:57 PM
J2turbo21's Avatar
Check out the link from importreview.
http://www.importreview.com/reviews/...n3VStyper.html
Im gonna go with them so that i wont have to upgrade my valvetrain.IR said that they are compatible with web cam valvetrain not like toda.
Old Feb 27, 2003 | 05:59 PM
Al Bundy's Avatar
I hear stories about timing belts shredding from CAM A and cams snapping from CAM S and then everyone assumes that they are both bad cams. A lot of people jump to conclusions.
I adjust my valves every 20k
Old Feb 27, 2003 | 06:04 PM
J2turbo21's Avatar
Hey Al Bundy did you every dyno the before and after?What kind of mods do you got?
Old Feb 27, 2003 | 06:09 PM
acydphryck's Avatar
they make the most whp more than any cam i have seen on the street. most of the street racers here in socal use them on their 'daily driven' street cars...
Old Feb 27, 2003 | 06:12 PM
Al Bundy's Avatar
Default Re: jun 3 cams (J2turbo21)
I don't think it would be a good idea to go with web valvetrain. You should stick to jun valvetrain or jun valvesprings with crower titanium retainers.
Old Feb 27, 2003 | 06:59 PM
1 2 NV's Avatar
ppl who spread rumors r like the worst diseases of this message board. i drove on my JUN 3s for over a yr NO PROBLEMS WHATSOEVER. ran on STOCK T BELT,no timing belt problems (always an issue with TODA) perfect idle, good power, perfect cam.
needs higher compression. id ONLY suggest JUN springs, id never buy a webcam product. needs good header to compliment them.
Old Feb 27, 2003 | 07:36 PM
Cow's Avatar
Cow
I didn't say anything about a bad cam; I just said it seemed reasonable to conclude that they would put more stress on the motor. Nothing at all wrong with the cam.
I've heard stories of cams breaking too, even JUN cams broke in someone's motor, that doesn't mean they are necessarily bad..
oh well. A strong timing belt just seems like cheap insurance to me.
Old Feb 27, 2003 | 09:48 PM
Kataku2K3's Avatar
JUN3s I would take them any day over SK2S2s and I've worked with them both... Normally the Skunks are more similar to an ITR/CTR/Toda cam which produce good midrange but the JUNs are very high strung.... Not to say that ITRs, CTRs, and Toda's aren't but those JUN3s scream on top end... They have a lot of overlap and you'll want to work them them on a high compression motor, your B18C with PR3 slugs should be cool... If you haven't already built the block I would consider P30's or PCT's.... Good Luck
Old Mar 5, 2003 | 08:02 AM
advanracing62's Avatar
Default Re: jun 3 cams (Kataku2K3)
I dynoed a stock B16 with JUN III cams at approx. 3000 ft. I pulled 33 hp over stock, with just cams. I used to daily my civic, but I don't want to deal with the cops anymore. I'm in the works of a 12.5:1 ITR with the JUN III head and some pnp... then it's time for tuning. I'm hoping for about 205 whp... then I'll drive the civic daily. I have no idle issues to speak of. Also it is interesting to not that a similar set up with SK2 cams only laid 26 over stock...
Old Mar 5, 2003 | 10:45 AM
ScubaStevo80's Avatar
Default Re: jun 3 cams (advanracing62)
You put down 30hp to the wheels over stock with just cams and nothing else on a b16a? So you're saying you went from 130ish to 160ish? I find that hard to believe, but then again I don' have much experience with cams. Do you have the dyno sheet? I'd like to see it
Old Mar 5, 2003 | 10:49 AM
Charlie Moua's Avatar
well my tech guys has them on his B16 and it's as quite as stock
Old Mar 5, 2003 | 10:53 AM
sgT's Avatar
sgT
Default Re: jun 3 cams (Charlie Moua)
be very careful when using jun springs. they bind at JUST past 12mm which
leaves very little margin for error. You MUST check install height when using
those springs. its very important.
Old Mar 5, 2003 | 03:09 PM
1 2 NV's Avatar
Default Re: jun 3 cams (sgT)
first off im prolly goin to b called a ****** idiot and whatnot but ive had my JUN head package in 2 different heads over the course of 3 yrs and had no problems at all. my rev limiter is set at 9200 and i never checked install height. dont know how to and i hear on honda heads its a pain in the ***. next yr i might buy new titanium retainers cause i hear they r a "wear" item and should b checked.
greeneg2.0
Oct 11, 2007 05:54 AM
JDMSI
Jan 21, 2003 02:26 PM
Rembrant Q. Einstein
May 20, 2002 11:47 PM
.Ryan
May 11, 2002 09:27 AM
SpoonFed
Dec 5, 2001 02:39 PM
