LS crank in a B18c block..
Old Feb 27, 2003 | 12:11 PM
Nameless RB26's Avatar
Default LS crank in a B18c block..
Will the B18 crank case hold an LS crank with the proper bearings? Or is it simply NOT possible to do with OEM parts?
Call me clueless.
Old Feb 27, 2003 | 01:28 PM
Default Re: LS crank in a B18c block.. (Nameless)
I read in another thread that the LS counterweights will hit the oil squirters.
Is that right??
Because that would suck..
Old Feb 27, 2003 | 02:17 PM
2000blackgsr's Avatar
i've heard an ls crank will work w/ the ls rods, this is hearsay since i've never done it before though
Old Feb 27, 2003 | 06:39 PM
Tbone's Avatar
Default Re: LS crank in a B18c block.. (96coupe)
yes you can, my last set up was a gsr block 84mm sleeves ,ls/crv crank , ls eagle rods, je pistons. My oil squirters were intact and operational.
Old Feb 27, 2003 | 10:29 PM
Default Re: LS crank in a B18c block.. (Tbone)
sweet. thank you.
Anyone else?
Gaspari
Sep 14, 2010 01:42 PM
haas480
Sep 1, 2009 04:09 AM
jordan2305
Dec 11, 2007 04:47 PM
gmacarize
Jul 26, 2006 08:16 PM
b18b-HB
Sep 2, 2002 06:08 PM
