B16 in a CRX, trouble, please help
Old Feb 26, 2003 | 07:07 AM
madman13lm's Avatar
Default B16 in a CRX, trouble, please help
https://honda-tech.com/zerothread?id=426585
Thanks
Old Feb 26, 2003 | 07:41 AM
you69's Avatar
Default Re: B16 in a CRX, trouble, please help (madman13lm)
Sounds like a head gasket. the antifreez went somewhere....either out the exhaust or in to the oil pan. i would say in to the pan(if the oil looks like milk). if this is the case drain the oil NOW because antifreeze isnt' good for bearings. do a compression/leak down test if your results are not good then i would do a head gasket.
Old Feb 26, 2003 | 10:17 AM
madman13lm's Avatar
Default Re: B16 in a CRX, trouble, please help (you69)
thats what I was afraid of
Old Feb 26, 2003 | 10:18 AM
madman13lm's Avatar
why would that stop me from going above 3000 RPM's? My friend had a blown head gasket and that didnt happen.
Old Feb 26, 2003 | 10:40 AM
Kataku2K3's Avatar
What model is your CRX?? Did you have to convert your wiring from DPI to MPI?? If so you would have had to wire in the CYP into the distributor and flip a lot of wires around (the DPI setup runs the TPS reference negative from that of any other NORMAL Honda so you have to flip wires)... Without this modification or having any of the distributor sensors (TDC, CKP, CYP) polarity mixed up you would have a ~3000rpm cutoff... How does the car idle??? Does it sound like a lawnmower?? If so I would check into the MAP vacuum and the TPS wiring... What ECU are you running, PR3 or PW0??? let me know and I'll see if i can help you more... Good Luck
Old Feb 26, 2003 | 12:06 PM
madman13lm's Avatar
Default Re: B16 in a CRX, trouble, please help (Kataku2K3)
I didnt do the swap myself, I just bought the car and the swap was already complete. It was running just fine until today. My friend seems to think that the ECU is putting a cutoff at 3k. Aparently its a safety mechanism. I will add coolant and try to reset the ECU and see what happens.
Old Feb 26, 2003 | 03:27 PM
Kataku2K3's Avatar
Oh really, safety mechanism huh... never heard of that??? oh well, good luck
Old Feb 27, 2003 | 05:04 AM
madman13lm's Avatar
Yep, thats exactly what it was. I filled it radiator and recharged the battery and it works fine
Cameronphelan
Honda Civic (2001 - 2005)
May 29, 2015 10:23 AM
b18_crx
Apr 27, 2005 12:18 PM
indy90turbocrx
Jan 12, 2005 11:28 AM
DsVtec2nrHBC
Dec 2, 2004 04:20 PM
RIOredKIRKLANDcrx
13
Jun 14, 2004 02:07 PM
