safe to bore?
Old Feb 28, 2003 | 10:18 PM
Dorikamu's Avatar
Default safe to bore?
This is the question how safe is it to bore a high mileage block?
This is my situation:
I am thinking of bore-ing my b18b, but the block already has 160k on it..
is it safe to bore it? If it is, what the max bore on stock block?
I am not planning to sleeve the block, and I am building a ls vtec which will not run more than 8000 rpm, no FI
[Modified by chusai, 2:20 AM 3/1/2003]
Old Mar 1, 2003 | 10:24 AM
Dorikamu's Avatar
Default Re: safe to bore? (chusai)
up
Old Mar 1, 2003 | 10:27 AM
altoid's Avatar
1 mm. but i wouldn't even bore it. just hone, 1 mm bore is waste and just weakens the walls. its about half a liter though. on the dseries anyway
[Modified by EE4, 2:28 PM 3/1/2003]
Old Mar 1, 2003 | 05:30 PM
joe_bocc's Avatar
Default Re: safe to bore? (EE4)
I second that. just hone it.
If you boring the block for the extra displacement don't bother. you will only pick up about 0.08 L of displacement.
Old Mar 1, 2003 | 06:22 PM
hotintegranights's Avatar
Default Re: safe to bore? (joe_bocc)
i would say bore it .025 over, and get it hone anymore than that might be asking for trouble unless you wanna resleeve it . also that ll bring your liter to a 1.8 1/2 .
also make sure you get itr/ctr 25bore pistons or anyother to match the walls.
Old Mar 1, 2003 | 08:50 PM
Jdm91Teg's Avatar
Default Re: safe to bore? (hotintegranights)
i just finished a b18a. I went 40 over on it its ok. FOR NOW
Old Mar 1, 2003 | 11:23 PM
todapower's Avatar
are you looking to bore for the power or because you have a chiped sleeve or something?
Old Mar 2, 2003 | 01:10 AM
Dorikamu's Avatar
Default Re: safe to bore? (todapower)
I am more looking to hone, I guess.. I just wanna make sure I get good compression when building the ls vtec.. since my block has high mileage.
But it will be nice to gain more power from bore, if it's safe to do so.
12secdc2
Dec 4, 2008 09:25 PM
imptricer
Jul 3, 2007 08:24 AM
sinister357
May 19, 2005 06:42 PM
awdriscol4
Nov 16, 2004 09:50 AM
