Can you calculate my new compression ratio after getting my head milled?
I had 8.5:1 compression. I had my head milled with 0.010 removed.
Can any one estimate what my new compression is?
Re: Can you calculate my new compression ratio after getting my head milled? (Hybrid)
Which motor is it? That is important. That milling should bump comprssion up 0.1-0.2 points
Re: Can you calculate my new compression ratio after getting my head milled? (xThexHeadx)
Z6 block with Y8 head, my Arias pistons give me 8.5:1 compression ratio with that head/block combo.
So with the head milled 0.010 over, then my final compression is.....................................?
Re: Can you calculate my new compression ratio after getting my head milled? (turbodav)
.010 is equivalent to about .2-.3 points of compression. So you are at about 8.8:1
Re: Can you calculate my new compression ratio after getting my head milled? (AzSi22)
Re: Can you calculate my new compression ratio after getting my head milled? (slomofo)
Just curious, not trying to start anything. Why did you get low CR pistons and then get your head milled to raise the compression?
I blew the damn motor and damaged the head. Put it back together, realized this afterwords. Its winter here, so I have the car in peices. The head is not ready to go back on.
candy eg
06-28-2006 01:38 PM
Techna600f4i
06-19-2006 11:49 PM
Mentat Ghola
14
05-11-2004 02:35 PM
