Questions about 63403 crower cams
Old Feb 26, 2003 | 07:52 PM
Art701's Avatar
Default Questions about 63403 crower cams
these are the stage 3 cams for DOHC VTEC motors. . .i was wondering if they were streetable? and if the Valve train does have to be upgraded? the reason, i found a good deal (on H-T of course), but the seller says he was using the set up on portflow inners, and Type R outers (intake springs for both intake and exhaust revving to 9K), he sounds like a reputable seller, but just i want to make sure that it is safe, and worth driving on the street (gas and idle). . .TIA for any input
Old Feb 26, 2003 | 08:15 PM
Art701's Avatar
Default Re: Questions about 63403 crower cams (Art701)
anyone?
Old Feb 27, 2003 | 07:43 AM
VTEC-DA's Avatar
Yes, they are streetable and yes you will need the upgraded valvetrain. As far as which valvetrain will work best, I couldnt tell you that, but I can tell you that the stock valvetrain wont cut it.
Old Feb 27, 2003 | 07:52 AM
b18c333's Avatar
Default Re: Questions about 63403 crower cams (VTEC-DA)
I have had 403's in my gsr for over a year now. I went with a valve spring and retainer package from web cam and have not had any problems with them. The car idles fine with a chipped b16 ecu and my VAFC leaned out 30% at 1000 rpm. I wouldn't recommend using them without aftermarket valvetrain components. God luck.
Old Feb 28, 2003 | 10:53 PM
Art701's Avatar
Default Re: Questions about 63403 crower cams (b18c333)
thanks for the replies, i am leaning towards getting the webb valve train also..
Old Dec 12, 2003 | 12:28 PM
naturelovindc2's Avatar
I'm bringing this one up from the dead. My old screen name was b18c333^^^
The Web Cam valve spring kit took a **** on me. I started hearing a ticking noise from the motor when driving home from work. I wasn't getting on it at all. Took of the valve cover and found two outers and an inner had broken on me.
<---- Check out my avatar. That's a pice of one of them that I found in my block.
starcraftbw
20
Aug 14, 2007 05:45 PM
lowsiciv
Nov 28, 2006 12:27 PM
Blade121
Jul 13, 2006 05:57 PM
jonathan13
Jul 6, 2006 01:45 AM
velocitytrends
Apr 29, 2004 04:01 PM
