First Gen Apexi RSM problem....help needed!!
Old Feb 26, 2003 | 11:46 AM
mugenracer's Avatar
Default First Gen Apexi RSM problem....help needed!!
I just fitted a first gen rev speed meter, and followed the set up instructions from the manual i downloaded. everything worked fine and i thought it was working 100% until i went over 140kmph, and thats where the speedometer stopped reading, it just stuck at 140kmph even though i was going faster than that. I went back home and unplugged it and went through the set up again, and still it wont read over 140kmph. I only used the basic connections as i already have the speed limiter removed from my jdm integra and didnt need to connect up the de-limiter wires to the ECU. I have gone through the set up again and again and i cant figure out what i'm doing wrong! Could someone who has the apexi RSM fitted please give me some help, the downloaded manual isnt much help (they even have a mistake in the ECU wiring diagram!) and theres no trouble shooting section, nor a wiring diagram if you want to wire the ecu for removing the speed limiter.
Old Feb 26, 2003 | 11:50 AM
orange.honda's Avatar
Default Re: First Gen Apexi RSM problem....help needed!! (mugenracer)
i have noticed with all of my endevores that not having extra parts in the end makes things work properly. maybe the rsm still thinks you have a limiter. you should hook it all up.
[Modified by orange.honda, 8:50 PM 2/26/2003]
Old Feb 27, 2003 | 07:35 AM
mugenracer's Avatar
Default Re: First Gen Apexi RSM problem....help needed!! (orange.honda)
that may be true but 140kmph is only 87mph and limiter on jdm cars is set at 180kmph so it should at least read up to that if it thinks the limiter is still hooked up!
Old Feb 27, 2003 | 08:37 AM
MikeMAN's Avatar
double check ur settings, i haven't delt with one of the 1st gen ones, but mine did the same thing until i found the right speed pulse setting (or whatever its called) and my tire diameter and weight were right.
mike
good luck!
Listerofsmeg
Apr 2, 2011 04:12 AM
Tink2150
Oct 5, 2005 06:46 PM
LiLxrAYCeR
Nov 7, 2002 05:21 AM
