No air from the a/c
Old Feb 27, 2003 | 11:39 PM
RebelleadeR's Avatar
Default No air from the a/c
I was wondering if this problem every happened to one you guy's, or maybe you could tell me what it might be.......
my a/c worked fine last night but the next morning it didn't come on.
It's been two days now and it still hasn't come on.
So what could it be? Do you think it will cost alot to fix?
Need help..
Old Feb 28, 2003 | 04:43 AM
Cuong-nutz's Avatar
Default Re: No air from the a/c (RebelleadeR)
Air you saying the fan isn't working or the a/c compressor not turning on?
Old Mar 2, 2003 | 12:26 AM
Default Re: No air from the a/c (Cuong-nutz)
the compressor isn't coming on..
Old Mar 2, 2003 | 11:04 AM
Cuong-nutz's Avatar
Check the relay/fuse
Old Mar 2, 2003 | 12:39 PM
McFly's Avatar
There could be ant number of reasons why your A/C compressor isn't comming on. Obviously a fuse or relay could do it and beyond thar it could be low refirgerant charge, bad pressure switch, bad clutch coil, bad heater control pannel, bad connection some where. I have seen all of these happen. I would recomend taking it to a shop if the fuses and relays are ok unless you know what you are looking for.
g4384063
54
Sep 7, 2023 09:48 AM
ek.troy
Honda Civic (2006 - 2015)
Jun 14, 2015 06:38 AM
delta901
Jul 17, 2005 03:15 PM
veggiemaster
Sep 28, 2004 08:56 PM
Zubz
Audio / Security / Video
Sep 3, 2002 09:49 AM
