BRAKE help........!!!!!!!!!!
Old Feb 28, 2003 | 06:53 PM
PinchE NegRo's Avatar
Default BRAKE help........!!!!!!!!!!
Sup..... Check it out.... I got a EK and need's brakes! I have a stock brakes system right now but want and need to upgrade. The rotors are small, i can fit 13" wheels, i want bigger rotors. Wut do u guys recomend??? Upgrade to bigger HONDA rotors like SI's or GSR's or get some rotors and calipers from some other NAME BRAND.....??? Please help....... All i got is $300 to invest, so wut would be the best move....???? thanx.......
-PLEASE HELP!!!
Old Feb 28, 2003 | 08:05 PM
cjohnson_2's Avatar
Default Re: BRAKE help........!!!!!!!!!! (EK-TUNED)
I think your gonna have a hard time upgrading your brakes besides the normal performance brake pads for just 300 bucks.
Even if you did get bigger rotors youd have to remount your calipers to allow them to fit.. and it wouldnt even make a difference unless you got rotors and calipers. if you reused your stock calipers on your upgraded rotors youd still have the same surface area stopping you...
Old Mar 1, 2003 | 04:12 PM
this is my 200th posts.......cool!
free bump.......
Old Mar 1, 2003 | 05:12 PM
joe_bocc's Avatar
With $300, the best thing you can do is get a set of new pads with a higher performance compound and maybe some SS brake lines. Although this will make an improvement, I think you should just save up and get an 4 wheel Si or GSR brake system. The brakes you have now will eventually get to the point where you can't do much more to improve the pereformance and then what?
Old Mar 1, 2003 | 10:11 PM
i cant just get pads, my rotors are horrible i have to get rotors....
-how much does a SI set run for???
Old Mar 2, 2003 | 04:38 PM
bump.....
Old Mar 2, 2003 | 04:47 PM
hatchdrvr's Avatar
heres the best deal if you want to upgrade. get Civic EX or Integra hubs and spindles and calipers from a salvage yard or try http://www.car-part.com, they should be about $100-$125, get factory Honda pads and stainless steel lines from http://www.manhonda.com for about $150. Then go to local autoparts store and get new rotors for about $30 a piece or you can spring for cross drilled Brembos on Ebay or something. It may be a little over $300, but it will give you the result you are looking for. Hope this helps.
Old Mar 3, 2003 | 07:13 PM
Default Re: BRAKE help........!!!!!!!!!! (hatchdrvr)
thanx for the help......
deviant1
19
Dec 14, 2002 01:23 PM
shamoo
25
May 31, 2002 09:54 PM
greensleeper
Apr 8, 2002 01:19 PM
nerdish
Jul 9, 2001 11:54 AM
