answer!!!!!
Old Feb 26, 2003 | 02:19 PM
CrazyKoreanCrx's Avatar
Default answer!!!!!
What is the different betwwen b16a and b16a2 heads? I need to know before i start buy these heads
Old Feb 26, 2003 | 02:23 PM
Katman's Avatar
Default Re: answer!!!!! (CrazyKoreanCrx)
nothing big really.
The only difference in the bare heads is the coolant passages. Other than that, either head share compatible parts. but if you're buying a used head and you have a choice between an 89-91 and 92-95 B16A(2) PR3 head ...go with the B16A2 head since it will have lower miles on it...unless your planning to rebuild the whole head (valve seals & all) it doesnt matter which one you get.
[Modified by Katman, 3:23 PM 2/26/2003]
Old Feb 26, 2003 | 02:25 PM
Default Re: answer!!!!! (Katman)
the bottom in is a b16a2 and the top (maybe) is a b16a that is ported and polished
Old Feb 26, 2003 | 02:28 PM
orange.honda's Avatar
dont know if this will halep but id like to call attenion to a prior post i read this morning entitled "weird stuff on by b16 sir" some one posted that the b16a2 has inner and outer valve springs and the b16a1 does not. like i said i dont know if it helps im more of a sohc guy. peace
Old Feb 26, 2003 | 03:01 PM
Katman's Avatar
Default Re: answer!!!!! (orange.honda)
actually that's correct, as far as Auto 89-91 B16A heads go....they have single valve springs on the both sides of the head. For 89-91 PR3 5speed heads the intake has dual springs, not sure about exhauast side though.
Old Feb 26, 2003 | 03:05 PM
just know that my b16a2 is from a 2000 si and the b16a is a fisrt gen
and i know that both have the samething on it except the intake ports and the lap(somethin)
there off but 5
Old Feb 26, 2003 | 03:09 PM
sleedawg's Avatar
Exhaust side does not have dual springs. That's why when upgrading to a ITR/CTR cam or any agressive exhaust cam, it suggested to get dual springs on the exhaust side. One note, if you do upgrade to the dual exhaust side springs, DO NOT get the Type-R springs as the Type-R springs have a softer spring rate than the other factory valve springs (GSR/B16) because the Type-R valves were lighter. People think Type-R ALWAYS means better. Type-R just means engineered for use w. other Type-R stuff. Just my $.02
oMek
Apr 11, 2004 08:37 PM
Vsm Hatch
Aug 27, 2002 09:51 PM
Ri5e
Aug 21, 2002 08:05 PM
