OBD2 a or b? ....what years?
Old Feb 28, 2003 | 07:45 AM
4g4me's Avatar
Default OBD2 a or b? ....what years?
HOndata says that they make ecu conversions for OBD2a(96-97) and OBD2b(98-00)
NOw I have a 98 hatch, build date 6/98, which system do I have? IS there a way to tell by looking at something? I was pretty sure OBD2b started in the year 1999.
This would be great if my car was obd2b, is HONDATA's reference wrong?????
Old Feb 28, 2003 | 08:12 AM
civicrtype's Avatar
Default Re: OBD2 a or b? ....what years? (4g4me)
96-98 OBD2a (three ecu plugs for 5spd) 99-00 OBD2b (two ecu plugs for 5spd)
Old Feb 28, 2003 | 08:53 AM
B18C-EJ1
Guest
Posts: n/a
Look at your plug on the ecu.
They go from Left to Right.
a-b-c-d
If you have pins in
A-C-D
Then you have a 96-98
If you have pins in
A-B-C
Then you have a 99-00
If you need a harness adapter, I have them as well.
Check this post - https://honda-tech.com/zerothread?id=424583
Old Feb 28, 2003 | 10:06 AM
Katman's Avatar
here's a diagram to help you out:
Old Feb 28, 2003 | 10:16 AM
4g4me's Avatar
Default Re: OBD2 a or b? ....what years? (Katman)
thanks so much.....a picture....wow, thanks now I can find out.
katman, ok, this is what i have...I have a d16y8 from a 2000 EX going into my 98 DX hatch, and I have the 00 EX computer/harness as well. What is it going to take to make this work in my car? I really did not want to have to buy a 96-98 EX ECU/harness, so what can you do to help me?
[Modified by 4g4me, 1:18 PM 2/28/2003]
Old Feb 28, 2003 | 10:40 AM
Katman's Avatar
np on the image.
Well the 00 EX harness almost works in 96-98 civic's but not quite. There's some re-wiring modifications that need to be done to it, I hear it's a bitch though (never did one myself).
I suggest you sell or trade the '00 EX harness + ECU and find yourself a 96-98 EX engine harness + ECU. If you go this route, everything will plug n' play; no wiring needed. That's the easiest solution.
I'd check your local junkyard to see if they'll trade you those parts.
Old Feb 28, 2003 | 12:42 PM
4g4me's Avatar
ok, the ecu is not that big of a deal.
But the wiring harness is....honda wants too much for one, and there are no local junkyards that carry civics.
So if I get the ECU, can I run the extra wires to make my dx harness work witht he new vtec engine? Spool, press., etc.////???
Old Feb 28, 2003 | 01:09 PM
Katman's Avatar
-- ok.
-- how about buying a used 96-98 EX harness off some on the net? such as HT classifieds....take a looksy
So if I get the ECU, can I run the extra wires to make my dx harness work witht he new vtec engine? Spool, press., etc.???
-- You sure can! I suggest this route if you indefinitely cannot find a 96-98 EX harness.
titosek4
Aug 12, 2009 09:24 AM
CivicSwapper
Nov 6, 2006 02:08 PM
b2Ovtec
Nov 8, 2003 03:27 PM
RacerXI
Oct 21, 2002 11:17 AM
Propulsion
Aug 20, 2002 09:43 AM
