please help!!!!!!!!!
Old Feb 26, 2003 | 03:29 PM
Nice_Dc2r's Avatar
Default please help!!!!!!!!!
i have a 1998 jdm b16a w/out lsd in a 1992 cx and i am using 1995 del sol axles
the driveres side axle goes in and out of the tranny as the car rolls. you can see the steering wheel move back and forth if i am going slow
if anybody nows whats causing this please help
Old Feb 26, 2003 | 04:27 PM
civicrtype's Avatar
Default Re: please help!!!!!!!!! (nice_eg)
If the axle is going in and out of the tranny then u gotta pull it out and make sure the C-Clip at the end of the axle is still there cause thats what locks it into the transmission. I wouldn't drive around like that so try to do it asap. Good luck.
Old Feb 26, 2003 | 04:32 PM
poison's Avatar
You will want to make sure the axles are properly into the tranny by snapping in.
Also check your inner cv joint on the driver side and make sure the shaft is properly in the CV joint.
keithly
Jan 15, 2017 09:23 PM
Prudz_lude
May 14, 2013 12:54 AM
1BADEGDC2
Transmission & Drivetrain
10
Oct 6, 2009 02:40 PM
ramtyper19
Nov 10, 2005 06:19 PM
Egone
Jul 17, 2003 12:23 PM
