Squeeling noise...
Old Feb 27, 2003 | 04:06 PM
SlowB16's Avatar
Default Squeeling noise...
A few weeks ago I was taking my FMU off and some gas got around the area of the alternator, so I thought I would flush the area out just to make sure the alternator didnt get messed up. Now when the rpm's are between about 1000-2400 there is this sueeling noise. It isnt that bad around 1000 but as the rpm's climb to 2400 the noise gets really loud then abruptly stops at 2400.
Does anyone know what this could be? I figure a belt is loose or something, but Im not sure. THanks alot.
....the other day I saw this girl cover her ears when I drive by, I thought that was funny
Old Feb 27, 2003 | 05:17 PM
SlowB16's Avatar
Default Re: Squeeling noise... (SlowB16)
anyone
Old Feb 27, 2003 | 05:44 PM
altoid's Avatar
if you took the belt off you could have put it on backwards. Or the gas could have just destroyed the lube in the alternator if it actually got inside of it.
Old Feb 27, 2003 | 10:46 PM
SlowB16's Avatar
Default Re: Squeeling noise... (Esquared4)
I bet that is what happened. I think a bit of the gas did get inside of it. Is there a way to fix that? Or with my luck I will need a whole new alternator......????
Old Feb 27, 2003 | 11:23 PM
Spartanic's Avatar
you'll definity need a new alternator if the protetive film inside is damaged.
Old Feb 28, 2003 | 11:45 AM
SlowB16's Avatar
Default Re: Squeeling noise... (Spartanic)
damn it
Old Mar 3, 2003 | 10:35 AM
tpr's Avatar
tpr
Tighten the alternator belt or better still get a new one and tighten it properly. The squeeling is most likely the belt slipping. at higher sppeds it heats the belt up enough to get grip sorta like race tires they don't stick till they get hot. however in thos case hot is bad. If that does not solve the problem then look at the alternator.
Old Feb 18, 2009 | 07:26 AM
Mr EG's Avatar
I'm having a squeeling noise as well coming from the belts. When I pop the hood I can hear it right around the alt. area and in the morning when it's cold. How do I tighten the belt?
TehGhett0P1mp
Aug 7, 2008 06:13 PM
kublai
Nov 3, 2006 03:34 PM
00civicsimobstyle
18
Aug 9, 2005 11:21 AM
RCautoworks
Jan 16, 2004 12:26 PM
