CHECK ENGINE LIGHT!!!!!!! code 23
Old Feb 28, 2003 | 06:13 PM
Grocery Getter's Avatar
Default CHECK ENGINE LIGHT!!!!!!! code 23
what is it!!!!!!!!!
i need to know fast....
not my car but hey i need the info.
-timmy
Old Feb 28, 2003 | 06:19 PM
94TealGSR's Avatar
Default Re: CHECK ENGINE LIGHT!!!!!!! code 23 (Grocery Getter)
Knock sensor. Either not plugged in, you don't have one, or the one you have is bad. It's on the back of the block, under the intake manifold on the drivers side. (on my GS-R anyway.)
Old Feb 28, 2003 | 06:24 PM
Default Re: CHECK ENGINE LIGHT!!!!!!! code 23 (94TealGSR)
thanks ill let him know.
Old Mar 1, 2003 | 06:34 AM
once again thanks for the help,
but one thing i noticed on the car,
was that he has no knock sensor, on the back of the block and no plug for it either,
so how does that work?
the reason it came on was because we went from a chipped ecu to a real spoon one.
the spoon one threw the code, the only thing i can think is that the spoon ecu runs the knock sensor and the chipped mugen on doesnt, now does he have to go get a knock senor put in? and how is he supposed to have that wired up?
-tim
Old Mar 1, 2003 | 07:02 AM
PhatOptimo's Avatar
The knock sensor screws into the back of the vtec block. Yes he will need a knock sensor if he wants the code to disappear. What motor does he have (must be an LS/vtec)? Knock sensors are easy to get a hold of. You will also need the wire harness plug for it. Put the chipped ecu back in until you get the sensor and wiring installed. You will have to run one wire to the ECU for the knock sensor.
Old Mar 1, 2003 | 07:21 AM
Default Re: CHECK ENGINE LIGHT!!!!!!! code 23 (Phat_Optimo)
thanks for the 411, we have already put his chipped ecu back in.
the motor he is running is a b16 gen2 5series.(thought i would throw the extras in. )
anyways, yeah i have an extra block laying around i will use that one, but i got to find him a plug for it.
but thanks again for the information.
-timmy
9deuce9rr
May 16, 2005 08:40 PM
THE94GSR
Jun 17, 2004 04:35 PM
Trygge
May 14, 2004 09:16 PM
CRexcellence
Apr 29, 2003 09:05 AM
clean99teg
Sep 21, 2002 05:43 PM
