b&m fuel gauge (help)
Old Feb 28, 2003 | 03:49 PM
Kermit EK's Avatar
Default b&m fuel gauge (help)
Okay so the proper place to read fuel pressure is at the rail so can the gauge be put on the rail with the hardware that comes in the kit? My kit has two fittings,(banjo bolt, 90%,and washer w/the gauge) can I mount it on the rail using just what I described above? And what is the stock fuel pressure suppose to be on a stock b16a motor? thanks!
Old Feb 28, 2003 | 04:20 PM
92hatchattack's Avatar
Default Re: b&m fuel gauge (Kermit EK)
i have an aem fuel rail, and the fittings that came with the package did not allow me to fit it on there--- i have to measure and order attachment fitting--- for now i just stuck it on the fuel filter------i do belive stock b16a fuell pressure is 38psi
Old Feb 28, 2003 | 08:21 PM
TimoneX's Avatar
New User
Default Re: b&m fuel gauge (92hatchattack)
I can't think how you'd put it on the rail. I put mine on the filter. Seems to work fine.
Jonathan_ED3
Sep 9, 2012 08:20 PM
AgentJam
Oct 26, 2004 04:33 PM
alpha
Jun 14, 2003 07:19 PM
b18cya
Apr 10, 2003 09:24 AM
Accord EX F22
Aug 9, 2001 05:07 PM
