CTR pistons in a B-16A
Old Feb 27, 2003 | 09:40 AM
egchan's Avatar
Default CTR pistons in a B-16A
I have CTR pistons and rods. Can I mill the head and use crower 402's and have sufficient piston to valve clearance? Whats the compression ratio w/o milling the head? Friend had the same CTR setup w/o cams and was fine but some people told me I couldn't mill the head and have clearnace. I have been told my compression will be 12:1 by just adding the pistons. Is this true? What are my options w/ my head if I used the CTR setup? Thanks
Old Feb 27, 2003 | 11:57 AM
evo's Avatar
evo
New User
Default Re: CTR pistons in a B-16A (SlickCRX)
I'm running JUN III, CTR pistons, 2 thos milled don't have problem.
Is B16A.
Old Feb 27, 2003 | 12:30 PM
Cashflo's Avatar
Default Re: CTR pistons in a B-16A (evo)
no it would not be 12:1 it would be around 10.8:1 in your b16a. Since your head is milled i cant tell you what your c/r is going to be. 12:1 would apply to a b18c with ctr pistons, When you increase the stroke it also increases the compression ratio. ues this reference: http://www.c-speedracing.com/howto/c...c/compcalc.php hope that helps
shortshift89
Jun 12, 2009 02:56 PM
RICE POLICE SIP
Mar 9, 2003 12:25 AM
enhancedCL9
Oct 8, 2002 11:31 AM
ITR111
Aug 31, 2001 02:19 PM
