fields or vafc?
Old Feb 26, 2003 | 09:15 AM
warwagon's Avatar
Default fields or vafc?
which is better and which is easier to use?
Old Feb 26, 2003 | 10:03 AM
Dual Cams's Avatar
Default Re: fields or vafc? (warwagon)
Go with apex Vafc... its better and it won't give you any check engine lights
Old Feb 26, 2003 | 12:05 PM
Built to Spill's Avatar
el diablo
Default Re: fields or vafc? (Dual Cams)
i would go with the vafc too...but it will give you check engine lights.At least mine did. Just make sure its installed correctly.
________
Mflb
Old Feb 26, 2003 | 12:24 PM
Katman's Avatar
yeah VAFC fo' sho.
SFC have a tendency to get shatty after a while, and mess (throw mil code) with the Map sensor.
[Modified by Katman, 3:20 PM 2/26/2003]
Old Feb 26, 2003 | 01:12 PM
warwagon's Avatar
Default Re: fields or vafc? (Katman)
well since i already have one i guess i'll just use it, but i am gonna hide it in the glove box
Old Feb 26, 2003 | 03:30 PM
pennies_hatchie's Avatar
than why are you telling us if its suppose to be hidden
Old Feb 26, 2003 | 03:55 PM
skunked's Avatar
Default Re: fields or vafc? (pennies_hatchie)
I have the fields, and like Katman said they start falling apart after a while. If I hit a hard bump in the road my car will start missing and throw a engine light. It rarely happens now that I have mounted the unit better but it still sucks to have to deal with that BS when you don't have to.
Old Feb 26, 2003 | 04:07 PM
warwagon's Avatar
ha ha i just dont like it sitting down there getting in the way
Old Feb 27, 2003 | 03:08 AM
Xsi's Avatar
Xsi
Default Re: fields or vafc? (skunked)
I had problems with the SFC throwing codes but I'm pretty sure it was the wiring loom because I've had no problems since I soldered the wires straight to the circuitboard.
Old Feb 27, 2003 | 04:08 AM
eg6ajk's Avatar
never had a VAFC, so no comments there.
but I used Fields and my review is mixed. basically depending on what you got, so will tend to cause problems others will not. mine is fine 90% of the time.
but once it gets really cold (around -10-30*C) damn thing causes problem. others don't have that problem involved with it.
Old Feb 27, 2003 | 08:52 AM
Default Re: fields or vafc? (eg6ajk)
i recommand the vafc...
maybe because thats what i have
Old Feb 27, 2003 | 09:42 AM
osf's Avatar
osf
Could someone with a vafc tell me if it took out the speed govenor on your obd2?
twiztid00002
Jan 14, 2008 09:31 PM
South Bay Surfer
Dec 24, 2004 02:15 PM
BseriesHatch
Dec 29, 2003 12:26 PM
evo
Apr 6, 2003 09:32 AM
