I got a B18b automatic engine...
Old Feb 28, 2003 | 11:31 AM
SupaFly_Honda's Avatar
Default I got a B18b automatic engine...
and wanted to change the automatic transmission to a 5 speed. Do I just take the automatic transmission off and put the 5 speed trans on? Or are there other things I got to replace and add? help asap!
Old Feb 28, 2003 | 11:37 AM
Spade's Avatar
Default Re: I got a B18b automatic engine... (SupaFly_Honda)
Yup. Just take the auto off and add a flywheel clutch and 5spd.
Old Feb 28, 2003 | 11:43 AM
Default Re: I got a B18b automatic engine... (Spade)
thanks bro.
Old Feb 28, 2003 | 03:07 PM
Lord Helmet's Avatar
don't forget the pedal assembly.
Old Feb 28, 2003 | 03:26 PM
Type Wah's Avatar
Default Re: I got a B18b automatic engine... (sleeperciv)
I'm definately gonna do this in teh future, how much will this total up to?
Old Feb 28, 2003 | 03:36 PM
icelarry27's Avatar
Default Re: I got a B18b automatic engine... (Type Wah)
what about the gearbox? you'd have to change that too right?
Old Feb 28, 2003 | 07:23 PM
brinks's Avatar
Default Re: I got a B18b automatic engine... (GRCuadros)
Old Feb 28, 2003 | 07:59 PM
VTEC-DA's Avatar
Default Re: I got a B18b automatic engine... (brinks)
Your gonna need a new shift **** also.
[Modified by VTEC-DA, 11:59 PM 2/28/2003]
Old Mar 3, 2003 | 09:54 AM
tpr's Avatar
tpr
What car are you putting it into? You'll need a 5 spd ECU, Pedal set, gauge cuuster (Shift lights for Auto are tacky), flywheel, clutch, release bearing, clutch cable or master/slave cyliner w/hydraulic line , Shifter/console, 5 spd transmission (SI version) and maybe a transmission motor mount from a donor car of the same gen as the motor came from.
whatthehell1051
Feb 19, 2006 10:17 AM
jdmekB18C
Jun 4, 2004 11:30 PM
zilverz
Apr 1, 2003 04:30 PM
JV
Feb 3, 2002 12:56 PM
