is it safe to drive with out thermostate?
Old Feb 27, 2003 | 11:54 AM
Charlie Moua's Avatar
Default is it safe to drive with out thermostate?
I'm wondering what will happen if i drive without a thermostate. I want my temp to be lower when I'm at the track but i don't want to get a mugen theromo.
will the car run ok?
Old Feb 27, 2003 | 12:05 PM
Perfectionist's Avatar
Default Re: is it safe to drive with out thermostate? (Charlie Moua)
The engine should operate in the temperature range it was designed for. Why would you run without a thermostat? The ECU will see the engine as cold and not run as efficiently. Yes, cold conditions call for a richer mixture, but this may not always be a good thing. The timing may be affected until warm up, I'm guessing. Probably a few other things I can't think of yet. I don't know, Im just making an educated guess here, but for daily driving, no t-stat is undesireable.
Old Feb 27, 2003 | 12:22 PM
0554's Avatar
Default Re: is it safe to drive with out thermostate? (Perfectionist)
all i did with my stock thermostat was drilled 5 or 6 tiny tiny tiny little holes in it so some water would always get through and that worked great it just takes little bit longer to warm up in the morning. it prolly takes likr 10 minutes or soo.
Old Feb 27, 2003 | 01:16 PM
saber1's Avatar
Default Re: is it safe to drive with out thermostate? (88crex)
You can usually get away with it for a short time, but I wouldn't run without a thermo indefinately. It is there for a reason. Don't doubt the big H guys in lab coats!
Old Feb 28, 2003 | 02:42 PM
PyroVTEC's Avatar
New User
Default Re: is it safe to drive with out thermostate? (saber1)
Man, I have a spare 160 degree thermostat... from what I know, all D and B series thermos are the same... maybe H-series as well, but not sure. Whoever's interested, shoot me a message... $15 shipped?
Old Mar 3, 2003 | 04:45 AM
Default Re: is it safe to drive with out thermostate? (PyroVTEC)
will it fit the f series ?
Old Mar 3, 2003 | 05:04 AM
hs2000's Avatar
I had a broken thermostate in my accord for a few months. It sucked, no heat.
Old Mar 3, 2003 | 07:18 AM
Default Re: is it safe to drive with out thermostate? (hs2000)
Did you notice any difference in performance, idel issues, & gas milage ?
Old Mar 3, 2003 | 07:49 AM
hs2000's Avatar
your car will idel higher if it is cold witch will bring your gas milage down. When I fixed it it seemed a little slower (could just be in my head) so I got aem cia and that seemed to bring all the power plus a little more back (but then agian that too could be in my head)
Old Mar 3, 2003 | 10:27 AM
Aron Parsons's Avatar
My god, put a thermostat in your vehicle. Don't treat the engine like crap b/c you think you'll gain .01 on your timeslip. If you want to improve performance, learn to drive.
Old Mar 3, 2003 | 02:13 PM
genetsang's Avatar
safe... sure.... in the winter.. youll have no heat.. in the summer... it acutally prevents overheating.. happened to me cus the car kept on overheating. so i yanked it out... and forgot to put it back in, during the winter.. so i froze.
Old Mar 3, 2003 | 02:35 PM
Default Re: is it safe to drive with out thermostate? (genetsang)
that's exactly what i planed on doing! thanks bro.
did you have any issues at all when you did that?
Old Mar 4, 2003 | 01:05 AM
CRVTEC96's Avatar
Check this out.......if you run with no thermostate the water will run though the engine non-stop. You do not want that because when it passes threw the radiator it will not get cooled down.....so its kinda pointless
Old Mar 4, 2003 | 03:06 AM
EE_Chris's Avatar
Default Re: is it safe to drive with out thermostate? (CRVTEC96)
The coolant has to have time to be able to absorb the engine heat, thus running with no thermostat might indicate a cooler water temp, but the engine will be hot.
Its there for a reason....so put one in.
[Modified by EE_Chris, 7:07 AM 3/4/2003]
Old Mar 4, 2003 | 03:49 AM
WTF the radiator has plently of area space to cool down the water before it re-enters the sleeve jackets.
Old Mar 4, 2003 | 06:12 AM
Vracer111's Avatar
That's not the problem, the problem is that the water doesn't spent enough time absorbing heat from the engine with an unrestricted flow rate - water has incredible thermal energy storage capabilites, but it's slow to absorb and and release that thermal energy because of its high specific heat index. When you take the thermostat out you are actually hurting the cooling system effeciency by allowing less engine heat to be absorbed. If the car is strictly a racing car you could just gut the valve of the thermostat or insert a restrictor plate so you can get proper flow at operating temperature. You can still do this with a street car, but it will take longer for the car to come up to operating temperature than with a thermostat.
[Modified by Vracer111, 9:22 AM 3/4/2003]
Old Mar 5, 2003 | 05:06 AM
Default Re: is it safe to drive with out thermostate? (Vracer111)
woah didn;t know that much about characteritics of water.
Thanks bro.
so what would you do if you wanted to motor to run cooler in the summer temp? My accord runs hottter than most because if a head swap i did to ^ the compression. In the winter the needle is almost touching the half way mark, I'm afraid it will really over-heat in the summer ; come temperture of 90F
Old Mar 5, 2003 | 05:40 AM
Vracer111's Avatar
If you think the car might run hotter than normal, then you might want to use less 'antifreeze' and more water in the radiator with a stock thermostat. 'Antifreeze' does help to raise the boiling point of the cooling system and provide some corrosion resistance, but it lowers the overall amount of heat that water can absorb from the engine.
Old Mar 5, 2003 | 05:42 AM
Hey i'll try that out. currently my mixture is about 70 coolant and 30 water.
is that okay?
is it okay to run all coolant an no water?
sorry for the newbie questions but this is somthing i never ran into.
Old Mar 5, 2003 | 07:25 AM
EE_Chris's Avatar
Water Wetter from Redline will also help out in your quest for cooler temps.
Old Mar 5, 2003 | 08:45 AM
NiiS's Avatar
Default Re: is it safe to drive with out thermostate? (EE_Chris)
Isnt that only dishsoap? There is a thread here somewhere that compares properties between the two...I'll post it if i can find it.
Old Mar 5, 2003 | 09:24 AM
NO that's not for me. This is my daily driven accord.
Old Mar 5, 2003 | 09:58 AM
RAWB's Avatar
Get a higher pressure radiator cap, this will raise the boiling point.
Also, 70 to 30 is about the max you want to go, just don't go lower than 44 percent coolant- this is when engine parts may be eroded by cavitation and cooling system components can be severely damaged by corosion.
Old Mar 5, 2003 | 07:39 PM
PyroVTEC's Avatar
New User
Default Re: is it safe to drive with out thermostate? (RAWB)
You're not serious about this are you? Cavitation might occur if you're overdriving the water pump. As long as there's coolant in the system, the water pump should be ok. As far as corrosion goes, there's little to corrode in Honda motors. In iron block & head motors like a small-block Chevy, yes that's true. Not so much on Honda motors. 44% coolant level is an awfully arbitrary number. An aribitrary number that's high at that--10-15% is more like it.
Yes, the thermostat is the same part number for D-series, B-series, and F-series... I just checked. I'm assuming this is for an Accord?
Old Mar 7, 2003 | 04:56 AM
SupaFly_Honda's Avatar
I'm glad I found this topic. Anyways does all B series share the same temp thermostat(160 degrees)? Also, can you buy different temperature thermostat from auto stores? The reason for my asking is becuase I have a 95 integra ls that I have own for 5 years, and within those 5 years I've had 3 blown radiators. My temperature needle is sitting just about in the middle and I can't get it to lower down.I can't figure out what the problem(s) is. I've changed the thermostat for every time that I had to replace my radiators. I'm thinking that maybe when I bought the thermostat the store probably gave me one that had a higher temparture reading instead of the original temp so causing my water/coolant to flow less frequently making my engine hotter then it should be? What do you guys think?
