ignition timing question
Old Feb 27, 2003 | 07:31 PM
Cory man's Avatar
Default ignition timing question
I was recently in a debate with a "know-it-all" and I need a question answered. When over advancing ignition timing will the ecu compensate and actually retard the timing a bit to prevent detonation? The "know-it-all" says it will, I say it wont. FWIW the car is a 95 b18b teg. TIA
Old Feb 27, 2003 | 07:57 PM
98AccordEX's Avatar
Default Re: ignition timing question (Cory man)
youre right
Old Feb 27, 2003 | 11:32 PM
Spartanic's Avatar
Yeap you are correct, the ECU wont retard it and if it did then why did honda make it so that you can adjust it??? hahaha.
Old Feb 27, 2003 | 11:36 PM
KTeller8's Avatar
Default Re: ignition timing question (Spartanic)
well on the accords
obd1 you can adjust it
obd2 the ecu will adjust itself
all in the computer
Old Feb 28, 2003 | 02:42 AM
Zero_son's Avatar
Default Re: ignition timing question (KTeller8)
That's kind of what the knock sensor is for... They adjust the timing in according to the base maps.
Old Feb 28, 2003 | 06:12 AM
advanracing62's Avatar
Default Re: ignition timing question (Zero_son)
it will, unless you're using a P28
Old Feb 28, 2003 | 06:14 AM
JimBlake's Avatar
In '95 the B18B didn't have a knock sensor. Only the GS-R (B18C) had one.
I don't think its quite correct to say that the knock sensor does the adjusting.
The timing goes according to its map, either way. It assumes the base timing is set to spec, so if you set your timing a couple degrees advanced, then the whole map will be moved up the same couple of degrees. IF IT WERE A GS-R then the knock sensor would be able to pull back the timing whenever it hears knocking. It doesn't pull back the whole map, & it doesn't remember to stay back for long.
KURUPTinc
Mar 10, 2008 08:52 PM
racer69
Jul 10, 2007 07:26 AM
dean2
Dec 27, 2006 11:21 AM
b20z2
Aug 8, 2005 11:57 AM
sleeperb16a
Nov 19, 2004 07:32 AM
