Motorheads I NEED HELP!!!!!!
Old Sep 24, 2007 | 04:53 PM
GSE980's Avatar
Default Motorheads I NEED HELP!!!!!!
Sup brothers...Im on deployment now so I cant actuaslly troubleshoot the problem myslef
I have a completly rebuilt engine new pistons bored out sleeves crank rods everything now my buddy mech. Is saying that the engine wont crank..manuallywith the tranny on??
It has even had its first start up yet . So a buddy of mine helped finsih putting the engine back in while I went on deployment.
At first he said I had my Del Sol clutch in the GSR which isn't right because I drove the engine before it was machined FINE without problems from the tranny. So he bought a new clutch put it on and now he is saying thats not the problem the tranny is from a del sol on a GSR once again I had this same tranny and engine driven around town before it was machined...
Any clue why my car isn't cranking does it have anythign to do with the tranny can you even bolt up a d16z6 tranny which was the orginal engine before I swapped and put it on a GSR IDK it sounds weird
any help I just want my car running when I come home
Modified by GSE980 at 7:10 PM 9/24/2007
Old Sep 25, 2007 | 08:05 AM
standbackimapro's Avatar
how are u putting a d16 tranny on a gsr?
Old Sep 25, 2007 | 08:19 AM
GSE980's Avatar
Default Re: (standbackimapro)
its not its the GSR tranny you cant even mate those two together
Old Sep 25, 2007 | 10:47 AM
Spoolin93si's Avatar
Default Re: (GSE980)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSE980 &raquo;</TD></TR><TR><TD CLASS="quote">Any clue why my car isn't cranking does it have anythign to do with the tranny can you even bolt up a d16z6 tranny which was the orginal engine before I swapped and put it on a GSR IDK it sounds weird</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSE980 &raquo;</TD></TR><TR><TD CLASS="quote">its not its the GSR tranny you cant even mate those two together</TD></TR></TABLE>
You do realize that you have just contradicted yourself.
Old Sep 25, 2007 | 09:51 PM
GSE980's Avatar
indeed I did that helps me out 0
thanks for nothing
Old Sep 25, 2007 | 10:01 PM
BILLETGRIP's Avatar
so could you ask your question again cause i really cant understand what your asking from your first post?
Old Sep 26, 2007 | 12:04 PM
GSE980's Avatar
okay
the mech says that when he mates my GSR tranny 2 the engine wont turn.... without the tranny it turns ...Whats the problem??
the tranny and clutch are both the same before the engine got machined.
Old Sep 26, 2007 | 01:34 PM
BILLETGRIP's Avatar
is everything bolted up and in the car?
Old Sep 26, 2007 | 05:04 PM
GSE980's Avatar
yes...but I haven't had a chance to look at myself because im out here so I guess Ill start a new thread when I get shoot it myslef
Old Oct 9, 2007 | 09:27 AM
GSE980's Avatar
so when you put the tranny on there is no clearnence on the pressure plate to the block or something like that and it wont let the flywheel spin
Monarch
Jul 22, 2002 05:09 PM
solsearching
Oct 3, 2001 10:24 AM
