oil filtering position
Old Sep 29, 2007 | 07:01 PM
quikflip27's Avatar
Default oil filtering position
quick questions:
on hondas, specifically the b series engines, where is the oil filtered as oil travels through the engine. as in: what is the order? does it go pan>pickup>pump>filter>oiling surface>back to pan
im not sure how to word this question properly, thanks in advance for any assistance.
also, is this where the filtering takes place in other engines also? such as other brands (nissan, toyota, mazda, chevy ect. ect.
-quikflip
Old Sep 29, 2007 | 11:19 PM
SlowReaction's Avatar
Default Re: oil filtering position (quikflip27)
As the motor is turning. the pump pulls oil from the pan through the oil pickup. from there it goes straight to the oil filter and out the filter back into the engine to lubricate all the needed parts.
Old Sep 30, 2007 | 11:03 AM
quikflip27's Avatar
ok, thank you. this brings up one more question.
on the filter, there is the main hole in the middle, and the smaller holes around the circumference. which is the inlet and which is the outlet?
thank you
-quikflip
Old Sep 30, 2007 | 03:22 PM
IN VTEC's Avatar
Default Re: (quikflip27)
In from the pump along the outer ring of smaller holes and into the block's main oil passage through the center of the filter.
Old Sep 30, 2007 | 04:58 PM
91DA9's Avatar
Default Re: (IN VTEC)
There is also an anti-drainback valve in the filter that is supposed prevent gravity from pulling the oil from the top of the engine back into the pan. I say "supposed to" because some filters use very crappy materials for this part and it ends up failing before it is time to change again.
While that scenario is not the end of the world, it can cause premature valvetrain wear, especially if the car does lots of on/off cycles.
Old Sep 30, 2007 | 06:17 PM
CarbonizedDX's Avatar
Default Re: (91DA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91DA9 &raquo;</TD></TR><TR><TD CLASS="quote">There is also an anti-drainback valve in the filter that is supposed prevent gravity from pulling the oil from the top of the engine back into the pan. I say "supposed to" because some filters use very crappy materials for this part and it ends up failing before it is time to change again.
While that scenario is not the end of the world, it can cause premature valvetrain wear, especially if the car does lots of on/off cycles.</TD></TR></TABLE>
OR if you get cheap *** filters (specially with oil change shops) they don't have the drain back valve....
Old Sep 30, 2007 | 07:48 PM
91DA9's Avatar
Default Re: (CarbonizedDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX &raquo;</TD></TR><TR><TD CLASS="quote">
OR if you get cheap *** filters (specially with oil change shops) they don't have the drain back valve....</TD></TR></TABLE>
I didn't realize they made filters without the drainback valve, but it does not surprise me. I always thought Fram's cardboard assembly was as cheap as it could get...
n77nxc
Aug 1, 2007 05:46 AM
00bluesi
May 23, 2004 07:31 PM
Sohc Driver
Jul 14, 2003 02:10 PM
RAS Motorsports
Jul 8, 2003 06:43 PM
h23accordlude
Jun 3, 2002 06:35 AM
