D16y7 in EG hatch smoking?
Old Sep 27, 2007 | 09:00 AM
Hondatuner88's Avatar
Default D16y7 in EG hatch smoking?
I have a question for everyone, my buddy has a hatch with a y7 motor and I can't figure out why it smokes only in the mid range and WOT. It does not lose and coolant or oil. Smells like gas all the time when running, I changed the regulator already, Still does it. Im thinking the injectors or the 02 sensor. Any ideas? TIA!!
Old Sep 27, 2007 | 09:19 AM
hatchling37's Avatar
Default Re: D16y7 in EG hatch smoking? (Hondatuner88)
Are you throwing codes? You might ( ) look for leaks if it reaks of gas all the time. That's bad. Check to make sure your EGR is hooked up properly. The ECU is going to make the car run rich at WOT anyway, so that's a main source of your smoke. The smoke is black, right?
Old Sep 27, 2007 | 10:23 AM
Default Re: D16y7 in EG hatch smoking? (hatchling37)
No leaks, Yeah the smoke is black but sometimes like a little whiteish, But not blue. And theres no oil on my back bumper or anything, The only code that comes up is for the atmosphic pressure or something like that, I will have to double check that tom, Thanks for your help tho!!
Old Sep 27, 2007 | 09:43 PM
92civicx's Avatar
white = coolent
blue = oil
black = ?
Old Sep 27, 2007 | 10:56 PM
doood's Avatar
been there done that
black means you're running rich. have a done a full tune up lately?
jawovanxion
12
Sep 18, 2012 05:38 PM
C00kiemunstr
10
Sep 12, 2008 12:48 PM
YodajdmEK4
10
Jun 30, 2007 06:04 PM
KW2000
Sep 19, 2003 12:27 PM
nicksweetlude
Feb 2, 2002 08:32 AM
