Help reading spark plugs
Old Sep 27, 2007 | 08:41 AM
Mr.Death's Avatar
Default Help reading spark plugs
I changed my oil and plugs yesturday on my new beater and I noticed the plugs looked fouled. Actually the plug nearset the timing belt looks good but as you make your way to the dizzy they get worse(fouled). It looks like carbon deposits with a bit of oil on the base of the threads in plug one(NEAREST DIZZY). The engine is a bone stock y7. Waht do you think?
Old Sep 27, 2007 | 09:21 AM
hatchling37's Avatar
Default Re: Help reading spark plugs (Mr.Death)
Do a compression test on the #3 and #4 cylinders. You have your numbers messed up on the plugs, by the way.
Old Sep 27, 2007 | 10:33 AM
Mr.Death's Avatar
Default Re: Help reading spark plugs (hatchling37)
Will do and thanks for clearing up my numbers.
Old Sep 27, 2007 | 11:15 AM
thesmogman's Avatar
What gap are you using? Just looks a little wide. Anyone else think so?
Old Sep 27, 2007 | 12:45 PM
Mr.Death's Avatar
Default Re: Help reading spark plugs (thesmogman)
Good question. They came with the car so I'm not sure, I'll have to check with my gapping tool.
Old Sep 28, 2007 | 12:45 AM
Mista Bone's Avatar
D Tranny Guru
REALLY Rich!- Rich - ok - ok
Nice temps on the electordes on 1-2-3 ground straps
Old Sep 28, 2007 | 07:44 AM
Mr.Death's Avatar
Default Re: (Mista Bone)
Compresssion results in! 180 across the board. What could cause my issue of being more rich on plug 1 then 2.3.4? Bad injector, rotor, plugs???
Thanks.
Old Sep 28, 2007 | 08:35 AM
Mr.Death's Avatar
Default Re: (Mr.Death)
Changed the plugs. oil addaed injector cleaner and tookher for a rip then checked the plugs. This is plug 4(nearest dizzy). Lots of carbon build up. Anyone?
frankenstienEk
Jan 15, 2007 04:10 PM
mickey513
Feb 23, 2004 05:41 PM
PressurizedSi
Nov 29, 2002 03:48 AM
ALLMOTOR18
Sep 10, 2002 03:05 PM
Floyd
Jun 18, 2002 01:35 AM
