Displacement 84mm or 85mm
Old Oct 4, 2007 | 10:47 AM
SiR Koopa's Avatar
Default Displacement 84mm or 85mm
to make it short im sleeving a b18c1 but i dont know if i should go 84 or 85, i know 85 is max but how reliable is it even when its sleeved? i know reliablity falls on the tuner but as far mechanically reliable is 85 safe? i plan on runing high 20's psi to get around low 500s
Old Oct 4, 2007 | 12:54 PM
Lubo_25's Avatar
Default Re: Displacement 84mm or 85mm (SiR Koopa)
id keep it low(82mm) for a boosted setup like that youre gonna need the extra meat between the cylinders...
Old Oct 4, 2007 | 04:16 PM
PHDZINE's Avatar
I always start off with 84mm...if I hurt the motor, I then go 84.5mm....then 85mm.
Old Oct 4, 2007 | 05:25 PM
LastGenEK's Avatar
Default Re: Displacement 84mm or 85mm (PHDZINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE &raquo;</TD></TR><TR><TD CLASS="quote">I always start off with 84mm...if I hurt the motor, I then go 84.5mm....then 85mm. </TD></TR></TABLE>
I would go 84 That would be a very nice motor. As far as reliabilty i dont see any problem Go for it
Old Oct 4, 2007 | 05:49 PM
doood's Avatar
been there done that
Default Re: Displacement 84mm or 85mm (LastGenEK)
good read: http://laskeyracing.com/shop/maxbore.htm
Old Oct 4, 2007 | 07:25 PM
SiR Koopa's Avatar
Default Re: Displacement 84mm or 85mm (doood)
thx for that site definitely helped understand the issue a little better. i appreciate the info
nvmeplz
135
Dec 29, 2006 03:20 PM
cltitus
Nov 13, 2005 04:30 PM
jman86
30
Jul 5, 2005 05:13 PM
mhgleitz
Nov 19, 2003 03:33 PM
93VAhatch
Oct 13, 2003 08:38 AM
