Ring Gap
Old Oct 4, 2007 | 10:02 PM
nblanton's Avatar
Default Ring Gap
I have a B18B block that I'm building a LS/VTEC with. I got it bored out to be .25mm over by a local shop that is fairly reputable in the SCCA crowd here in Raleigh. Well, anyway, I started putting everything together tonight, and everything was good until I checked my ring gaps. The Helm manual says I should see between .008" and .014" end gap about a half inch from the bottom of the bore with new rings. I'm getting around .018" to .019". This is within the service limit of .024". The question is, did I end up getting my block bored out too much? Have any you seen this? I'm using OEM .25mm over P30 rings and pistons.
Old Oct 5, 2007 | 03:14 PM
ekb16's Avatar
you might have to get bigger rings and file them down urself to the specs u want or have a shop do it...when i was building my k series block i filed my rings down myself with a file..takes awhile but cheaper than having a shop do it
Spoon84
Jul 19, 2010 01:34 PM
mvp100
Feb 22, 2008 07:06 AM
got wide
Sep 4, 2007 03:55 PM
FIGARILA
Jan 12, 2007 12:03 PM
Trey
Feb 17, 2003 04:49 PM
