Blown Oem headgasket?
Iv'e just blown my oem golden eagle headgasket with o ring. Is it ok to use a different type of headgasket such as cometic or etc.. or do I only have to use the oem oversize one from golden eagle with copper spray this time, but I still can't believe I blew a headgasket with a little more than over 800 miles on it and the block is o ringed how's this possible.
Modified by integraboosted at 7:55 AM 9/30/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraboosted »</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
X2, don't get cometic they are no good. OEM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 »</TD></TR><TR><TD CLASS="quote">did you have personal experiences with cometic or hear say stories??</TD></TR></TABLE>
Oh yeah I've seen cometic hg blown on one pass. my buddy than put on an OEM and has had the same hg for about 5 months now. you can also tell by the material both hg use. OEM for us.
It's just another bandwagon type thing. Sure OEM is great, but I've ALSO seen one blow on the first pass. You can't really determine a products quality by 1 example. But I've used cometic now for 3 years without a single HG problem. In fact, I just ordered another one for my car because I got a damn compression tester stuck in the head and I'm gonna have to remove it to get it out. Pain in the ***!!!
I say give it a shot. I've always been one to find out by doing it. If you never try, you may never know!!!
-James
-James
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORTant Si »</TD></TR><TR><TD CLASS="quote">It's just another bandwagon type thing. Sure OEM is great, but I've ALSO seen one blow on the first pass. You can't really determine a products quality by 1 example. But I've used cometic now for 3 years without a single HG problem. In fact, I just ordered another one for my car because I got a damn compression tester stuck in the head and I'm gonna have to remove it to get it out. Pain in the ***!!!
-James</TD></TR></TABLE> we do not sagest using a cometic gasket with a oringed block and nether does cometic. i have seen many head gasket problems with cometic gaskets and not had 1 problem with oem honda gaskets gardela ran oem gaskets in his honda cut by us eggum and bisi both also run oem honda gaskets with no problems. to the op pm sent
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 »</TD></TR><TR><TD CLASS="quote">so true man we live in a mass production world its the luck of the draw...</TD></TR></TABLE> with a oem gasket you dont have to worry about luck of the draw as long as you install them correctly they work even with high boost oem gaskets are all we use
Black DC2
Apr 17, 2005 05:16 AM
