ls/vtec headgasket
Old Sep 24, 2007 | 04:57 PM
brandnewman16's Avatar
Default ls/vtec headgasket
So i blew my headgasket today and am wanting to replace it tomorrow. My car is boosted and its a semi built ls/vtec. I think the company that built my motor put a factory head gasket in. Obviously, it couldnt hold it so I'm trying to figure out what to buy to put in it. the head was milled about 13 thousanths i believe and its an lsvtec. What do you all suggest as far as an upgraded headgasket?
Old Sep 24, 2007 | 10:35 PM
carcala's Avatar
Default Re: ls/vtec headgasket (brandnewman16)
do u have head studs? maybe the head lifted. factory head gasket is always a good choice. how many miles ont he motor?
Old Sep 25, 2007 | 05:25 AM
arp head studs, what do you mean the head lifted!? that sounds pretty crazy. has 800 miles on the motor since the rebuild, which was honed to 81.5 mm, eaglle rods, je pistons, arp head studs and rod bolts, acl main and rod bearings and some other stuff. It didnt see over 4k rpms and no boost until 500 miles.
Old Sep 25, 2007 | 05:41 AM
pgpbubble's Avatar
Default Re: (brandnewman16)
Head and block resurfaced? I've never had a problem with an OEM headgasket.
Old Sep 25, 2007 | 07:30 AM
yes, block was redone by ERL and the head was sent to bell. the rebuild total was 4k, it wasnt a **** job. Im thinking either the company that put it together messed something up or the head shop did. It just doesnt seem like a headgasket should blow after 800 miles! im so heated
Tong.Y
Jun 5, 2011 09:17 PM
ChRiS_p123
Apr 8, 2010 10:27 PM
sporkcrx
Apr 8, 2004 09:03 PM
servion
Mar 7, 2003 08:35 PM
zCivic
Jan 13, 2003 03:41 AM
