no VTEC after head gasket change
Old Oct 4, 2007 | 09:48 PM
eg6madness's Avatar
Default no VTEC after head gasket change
I got my head gasket changed last week, the mechanic got the milled a little as well. I got th car back and now i have no VTEC. since i have the Hondata S300 i tried different VTEC points and still nothing. the car never switches over.
Why would this happen?
Old Oct 6, 2007 | 08:20 AM
EK499's Avatar
hey, did you find the problem with your vtec? I'm planning to change my head gasket also...
Old Oct 6, 2007 | 04:40 PM
eg6madness's Avatar
Default Re: (EK499)
The VTEC is working sometimes but not all the time, seems as though it is working when it feels like it.
In some gears VTEC come on like 6000-7000. sometime it comes on at the usual 4700-5300. (since I have the the S300 i have the VTEC set using the "manifold pressure window" to allow VTEC to fluctuate the engagement point based on engine speed).
But it doesnt feel like it is engaging everytime. I just finished changine my oil and plugs. i will disable the window in a few mins and i will let you know later if VTEC is engaging.
Old Oct 7, 2007 | 06:09 AM
eg6madness's Avatar
Default Re: (eg6madness)
Ok, it seems as though it is engaging each time but due to the increase in more compression since the head was milled few thousandths and a 2 layers head gasket. The VTEC point i believe has to be shifted.
Because the change over is still at 4700,it doesnt "feel" like a kick. It changes over but i doesnt have the same effect. What i will do it play with the points and see where is best.
Old Oct 7, 2007 | 11:20 PM
blinx9900's Avatar
the cars gonna feel like a dog if vtecs not poppin, its gonna feel like power is linear or falling off. if its not popping id ask yourself if you installed the o ring and dowl pin thing that goes in the middle of the head... cant rememer the name sorry.
Old Oct 9, 2007 | 08:23 PM
eg6madness's Avatar
Default Re: (blinx9900)
what do you mean ? what o-ring thing?
Old Oct 9, 2007 | 09:20 PM
92civicx's Avatar
is your check engine light on?
Old Oct 9, 2007 | 09:45 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6madness &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean ? what o-ring thing?</TD></TR></TABLE>
there is an o ring and a dowl pin that goes under the cam cap that sits in the middle of the cams. if that thing is not installed you get no vtec... its a small part that may fall out, and if your an amature, you may not notice...
Old Oct 10, 2007 | 04:31 AM
eg6madness's Avatar
no check light isnt on.
if u mean th cam seal that sits near the end of the cam, yea those are in
Old Oct 10, 2007 | 08:53 AM
slomofo's Avatar
GDD Member
Didn't read the thread, but if this is a DOHC engine, you need to remove your cam cap/rails and reinstall them the right way.
Old Oct 10, 2007 | 11:05 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6madness &raquo;</TD></TR><TR><TD CLASS="quote">if u mean th cam seal that sits near the end of the cam, yea those are in</TD></TR></TABLE>
no this is not the cam seal, it sits int he middle of the cyl head, underneath the middle cam cap... bascially just like this guy said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Didn't read the thread, but if this is a DOHC engine, you need to remove your cam cap/rails and reinstall them the right way.</TD></TR></TABLE>
and hes just being lazy like me, its hard to explain, but i think it should be clear now? hopefully...
Jayden Kolera
Nov 7, 2024 02:07 PM
Crazyycivic98
Apr 13, 2015 05:01 PM
Luca
Sep 17, 2009 12:26 PM
turboteg185
Dec 28, 2007 08:42 PM
stickeyfingaz
Dec 29, 2004 10:19 AM
