clutch will not engage.
Old Sep 26, 2007 | 07:43 AM
Crispy's Avatar
Default clutch will not engage.
I have a strange problem that I was hoping you could all give me some insight into.
Somehow, my clutch is not engaging, I think. I can idle the car and shift through every gear and nothing happens . Clutch pedal feels fine, but I can move the slave in and out with my fingers. The clutch and flywheel are both oem and new. The car hasnt been driven other that moving it in and out of my garage since their install. Everything worked fine when I moved it the day before.
I wasnt even aware this was possible, Correct me if I'm wrong but isnt the natural state of the clutch to be engaged untill I release it?
If it helps it's a b20 block with a b16 trans.
Any ideas anyone?
Old Sep 26, 2007 | 11:11 AM
Crispy's Avatar
Default Re: clutch will not engage. (Crispy)
I'm too dumb to figure this out on my own
Old Sep 26, 2007 | 04:59 PM
97grnrs's Avatar
you prob have air in the lines?? did u open or dissconnect any of the hydro lines ??
Old Sep 26, 2007 | 05:36 PM
Dogginator's Avatar
Daisy... Daisy...
Cable or hydro? (What car is it?)
Old Sep 29, 2007 | 12:56 PM
Crispy's Avatar
Default Re: clutch will not engage. (Dogginator)
hydro. it's in an eg
I can push the clutch fork in with my hand with the car in gear andd the clutch pedal out.
Pressure plate stuck? but how on earth is that possible
Old Sep 29, 2007 | 01:17 PM
Dogginator's Avatar
Daisy... Daisy...
If the pressure plate bolts are loose, it would not engage.
Old Sep 29, 2007 | 03:42 PM
97grnrs's Avatar
im willing to bet u have air in the lines.. did u bleed it at all? symptom of really easy pedal is air..
Old Sep 29, 2007 | 11:15 PM
SlowReaction's Avatar
Default Re: clutch will not engage. (97grnrs)
car go in gears when the car is off? If so sounds like its going to be problem with the clutch install. Clutch will always be engaged until u push the pedal in. If it does not disengage when you step on the pedal it wont go in gear.
danno33
12
Sep 30, 2012 08:46 PM
danno33
Jul 14, 2009 07:45 AM
MichealSenior
Feb 17, 2009 12:56 AM
sdboostin111
Dec 5, 2006 07:48 AM
shhh151
Sep 8, 2005 05:42 PM
