Window keeps coming off track
Old Oct 6, 2007 | 01:16 AM
96cxhatch17's Avatar
Default Window keeps coming off track
I have a 2000 hatch and the driver side window keeps coming off track, so every once and a while when it decides to pop out i have to remove the door panel and put it back on track. Any ideas as to why this keeps hapening even after i put it back on track?
Old Oct 6, 2007 | 07:16 AM
tha_badguy's Avatar
lube!
Old Oct 7, 2007 | 03:23 PM
Default Re: (tha_badguy)
tried it i dont know why it keeps doing it, once you roll the window halfway down it starts to get hard to roll and then it pops off track
Old Oct 7, 2007 | 03:26 PM
tha_badguy's Avatar
what kind did u use?
Old Oct 9, 2007 | 01:47 PM
it was a white grease but i think im gonna try somethin else because that obviously doesnt seem to be working
Old Oct 9, 2007 | 06:32 PM
CarbonizedDX's Avatar
Default Re: (96cxhatch17)
I had the problem that when I rolled the window up the window would pop out of the track. I ended up replacing the window regulator unit and when I pulled the old one out I noticed the scissor assembly was wider when collapsed than the new one (meaning it was all kinds of bent out of shape, probably from previous attempts at theft...)...
Simple way to tell is look down the window while rolling it up or down with the interior panel off, if the scissor assembly looks really bowed out it's probably bent and needs to be replaced.... It's an expensive fix but I found it was the easiest thing to do beyond the guild I've got on how to "adjust" the tracks (send me a pm if you want it)...
Old Oct 9, 2007 | 06:55 PM
BrownDx's Avatar
Default Re: (CarbonizedDX)
I used to have the same problem until I replaced the regulator.
Mine was all twisted when I took it out.
A new one did the trick.
Old Oct 10, 2007 | 01:55 AM
jdmxsoles's Avatar
i had the same problem with my hatch finally that glass cracked on me and switched it and losened all the bolts and re-adjusted everything and then it was fine!
Old Oct 14, 2007 | 12:38 AM
Default Re: (jdmxsoles)
how much for the unit?
Old Oct 18, 2007 | 08:51 PM
vvsabvv's Avatar
hey carbonized can you post the how to adjust the tracks in this thread or in a new thread?
Old Oct 23, 2007 | 05:47 PM
Default Re: (vvsabvv)
pretty much all you need to do is loosen 2 10mm bolts that hold down the tracks, they are on the bottom of the door on the far left and right side and then readjust them so the window fits in them. its kind of a bitch to put the window in the left side track because theres not much space to move your arm around. (At least thats how it is for the EK)
Old Oct 23, 2007 | 09:34 PM
OversteerMotorSports's Avatar
You probably have a slightly bent window regulator.
Old Oct 24, 2007 | 07:33 AM
h22crxpwr's Avatar
Default Re: (OversteerMotorSports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OversteerMotorSports &raquo;</TD></TR><TR><TD CLASS="quote">You probably have a slightly bent window regulator. </TD></TR></TABLE>
x2 your window regulator is bent....
Old Oct 24, 2007 | 08:36 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Window keeps coming off track (96cxhatch17)
replace the regulator, then when you are replacing it clean the run channel with soap and water.
Modified by B16B_coupe at 5:38 AM 10/25/2007
Old Oct 24, 2007 | 07:49 PM
lovey408's Avatar
Default Re: Window keeps coming off track (B16B_coupe)
mine did the same thing over and over.. i opened the bolt and put it back on further on the rail thing.. it works perfect now and havent had a problem for almost 2 yrs.. only bad thing is the window goes down reallly slow wen it is at the bottom. but fixed the problem on a rainy day for me temp. jus never got back to fix it bak to normal
Old Nov 3, 2007 | 05:48 PM
Default Re: Window keeps coming off track (lovey408)
bump thanks for the input guys
Old Nov 4, 2007 | 04:32 AM
PepsiBlueSi's Avatar
Im going through the same problem right. One tech told me that it was the run channel and then someone else told me it was the regulator. It sounds like its the regulator. I priced it at the local honda dealership and it was 60 aft tax w/o the motor
Nighthawk7thGen
Honda Civic (2001 - 2005)
Sep 17, 2008 08:03 AM
MIKE_HWD
Sep 24, 2007 05:17 PM
hotdoggies
Feb 19, 2006 10:03 AM
EnKidu
Oct 12, 2004 07:08 PM
Agent Zero
Aug 13, 2004 01:53 PM
