b18b rocker help
Old Oct 1, 2007 | 04:01 PM
johnls's Avatar
Default b18b rocker help
well im rebuilding the motor and put the rocker arm in and try to adjust the valve but it would let the feeler gauge slide then i notice number on the side of the arm what order do they go or what are the number for if some one could help thanks
Modified by johnls at 7:26 PM 10/2/2007
Old Oct 2, 2007 | 05:04 AM
johnls's Avatar
Default Re: b18b rocker help (johnls)
bump for some help
Old Oct 2, 2007 | 06:07 AM
hatchling37's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnls &raquo;</TD></TR><TR><TD CLASS="quote">well im rebuilding the motor and put the rocker arm in and try to adjust the valve but it would let the feeler gauge slide then i notice nuber on the side of the arm what order do they go or what are the number for if some one could help thanks</TD></TR></TABLE>Why didn't you put it back together the way you took it apart. Get a Helms
Old Oct 2, 2007 | 06:26 PM
johnls's Avatar
Default Re: b18b rocker help (hatchling37)
what does the number mean
Old Oct 2, 2007 | 07:44 PM
LSTEG98's Avatar
bump i need to know as well
Old Oct 3, 2007 | 03:49 PM
projectTeG's Avatar
theres no order. the rockers are the same on both sides, just back the center screw off and adjust from there.
LSTEG98
Oct 3, 2007 04:28 AM
SOHC_me
Jul 15, 2007 03:30 PM
SOHC_me
Jul 13, 2007 10:55 AM
IHEARTMYHONDA91
Dec 29, 2006 08:46 PM
Thrillhouse
Mar 2, 2004 09:42 PM
