Melted IAT sensor
Old Sep 30, 2007 | 06:48 PM
all-mtr-teg's Avatar
Default Melted IAT sensor
Got a CEL code 10, pulled out the IAT sensor to replace it and the tip was melted. What could have caused this? Is timing off and causing heat to escape into the IM. Its a 97 gsr w/ S2 pro-series IM so IAT sensor mounts on 2nd cylinder runner a lot closer to the head than a stock IM.
Old Oct 1, 2007 | 08:00 AM
Relic1's Avatar
a very common source of this problem is having the EVAP purge and IAT plugs switched.
other than that there is very little that "should" be in that area that will ever be that hot.
Old Oct 1, 2007 | 09:10 AM
Default Re: (Relic1)
do you happen to know the colors of the wires that should be going to each sensor? Also, do you mean switching the IAT and the IAC plugs, I thought the EVAP Purge control solenoid runs off of vacuum not current?
Modified by all-mtr-teg at 10:21 AM 10/1/2007
Old Oct 1, 2007 | 10:07 AM
Relic1's Avatar
Default Re: (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">do you happen to know the colors of the wires that should be going to each sensor? Also, do you mean switching the IAT and the IAC plugs, I thought the EVAP Purge control solenoid runs off of vacuum not current? Modified by all-mtr-teg at 10:21 AM 10/1/2007</TD></TR></TABLE>
the 96-97 tegs are the two years I don't have manuals for.
the 98-01 uses the following colors
IAT - red/yellow - green/black
EVAP - black/white - blue
IACV - yellow/black - black/blue
94-95 teg uses
IAT - red/yellow - green/blue
EVAP - yellow/black - red
the EVAP purge solinoid routes fuel vapors traped in the charcoal canister to the intake manifold, but the solinoid is controlled by the ECU. the plugs for that and the IAT are the same and the wiring is about the same length.
Old Oct 1, 2007 | 01:28 PM
Okay, thanks for the help
Old Oct 1, 2007 | 07:33 PM
Hey thanks alot for the color codes, according to my wire harness the 97 is the same as the 94-95 colors, thanks again.
Old Oct 2, 2007 | 09:19 AM
Andrew Marquis's Avatar
Default Re: (solbrothers)
I had the same problem. This is what mine looked like in comparison to a new(er) one:
Just replace it, clear your ECU, and enjoy NOT staring at a CEL.
Old Oct 2, 2007 | 11:59 AM
Default Re: (Andrew Marquis)
Yup, mines looks just like that, put in a new sensor, now all is well
Steven Cortez
Nov 14, 2016 09:49 PM
mar7pau
Aug 29, 2010 10:34 AM
cd5ryan
Jun 29, 2010 07:30 PM
integra95gsr
Nov 8, 2004 12:06 PM
Snydog0510
Jun 16, 2003 08:52 PM
