tranny problem? it wont....
Old Oct 3, 2007 | 09:45 AM
ndlyng's Avatar
Default tranny problem? it wont....
When the engine is on, it will not go into any gears? When the engine is off, I will go into gears with no problem? I took the tranny off and replace the the cluth, used the same clutch plate, same results. Checked fluids and its fine. What do you guys think?
Old Oct 3, 2007 | 01:44 PM
King V's Avatar
Default Re: tranny problem? it wont.... (ndlyng)
Clutch isn't releasing for some reason. You check the TOB for fit/alignment?
ndlyng
Oct 4, 2007 03:46 PM
kid-honda
Apr 7, 2004 04:12 PM
