freshly built ls vtec, way low compression
alright so have searched for the answer, but it doesn't seem like anyone has encountered this problem before.
so i just completely built a lsvtec
b18a block, running 11.5 compression pistons, crank was micropolished and checked
the b16 head was checked and only needed one valve replaced, i'm running gsr cams
the car has about 1500 or so miles, and i had it tuned at about 800 or so miles
and it only made 148
so did a compression test, and read almost exactly 127 in all cylinders
the car is also burning a considerable amount of oil, about a quart and a half in 600 miles or so but no smoke from exhaust, but i did notice smoke coming from oil filler cap and valve cover breather when hose was taken off
checked the cam timing, no problem there
double checked and adjusted my valves and they were almost perfect
then double checked the torque on the head bolts and still nothing
i'm going to do a leakdown test tomorrow, but i just wanted to see if you guys had any ideas
i noticed that when i turned the motor to do the valve adjustments i could feel a lot of compression building, but then i could feel it release somewhere, so i'm guessing it probably isn't the cylinders
any suggestions or ideas would be greatly appreciated
thanks,
quaker
thanks,
quaker
Sounds like the rings weren't seating correctly. Try a wet compression test and see if the #'s go up or not. A leak down would also indicate where a leak (if there is one) coming from.
MBlake55
Jul 27, 2009 04:56 PM
blackeg
Mar 28, 2005 06:10 AM
